I need accurate information for my description in my train calendar I produce. How many total “Executive” SD70MAC units did Burlington Northern order before the BNSF merger was finalized December 31, 1996? I found a site that said “428” and another that says more than “350.” I need verification! Also, how many additional SD70MACs did BNSF continue to order after that 12-31-1996 merger? I don’t want to know anything other than "SD70MAC" units! Does anyone have accurate/reliable web links? Please don’t include any other variation but “SD70MAC” for BN/BNSF!!! [;)]
BN ordered 434 SD70MACs that were delivered in Green and Cream paint, 9400 - 9837, less the four SD60MACs 9500 - 9503. Within this range there were 62 locomotives ordered by BN and painted Green and Cream, but delivered after the merger and lettered BNSF, 9776 - 9837, and the locomotive painted in the Santa Fe scheme, but using BN Green and Creme paint, 9647. 352 SD70MACs 9838 - 9999 and 8800 - 8989 were ordered by BNSF and were delivered in the Orange and Dark Green H2 paint scheme.
Edit: Found some conflicting data with some information I had earlier posted. Not knowing what’s actually correct, I decided to withdraw my post.
After some digging, I do wonder however if some of those initial 350 units (That I was under the impression was later expanded to 425 units) took the form of options that weren’t officially picked up until after merger (It would explain some of the conflicting information I’ve encountered). If so, I’d argue such later units actually were BNSF ordered since an option isn’t officially an order until it’s picked up and converted into one.
Also, I’d have to disagree with some of JayBee’s paint data. I show the BNSF marked units in BN’s executive colors as 9711-9712 and 9717-9837. A spot check of several numbers has so far supported that.
You are correct that BNSF lettering started earlier with the locomotives that you indicated.
Orders for 350 locomotives is hard to pin down, originally the SD60MACs were to be rebuilt to production standards, do they count among the 350? In any case they were replaced by four new locomotives as EMD judged the cost too high to rebuild them. Notice that an order of 350 would take the series through 9753, but that is in the middle of a production order for locomotives through #9775 on sales order 956615. I think it is reasonable to conclude the next batch of SD70MACs built on order number 966706 was initiated by BN but delivered in Green and Creme after the date of the merger, this is the batch from 9776 through 9837. EMD order numbers indicate when serious discussions began for the purchase, and with a large number of the model already in service, likely the only thing BN needed was a cost quote, and then to get board approval for the purchase.
This very accurate Burlington Northern roster is perhaps of some possible use. It shows a total of 311 units rostered. Those shown are 9400-9499 and 9504-9775, which includes units built and delivered post-merger.
That suggests that up to and including 9716 were officially on the books Burlington Northern property, including several units delivered shortly after the merger (A total of 311 units).
9717-9775 (Order #956615) is also included but not actually rostered by Burlington Northern or included in the tally. Presumably this order for 59 units is listed since they were ordered by BN and thus are shown for the sake of completion even though when delivered they were full fledged BNSF property.
9776 through 9837’s order number was 966706 (Delivered during the first half or so of 1997). So if EMD order numbers indicate when serious discussions began with the potential customer, I assume that puts this order as 1996 and post-merger (Which would explain why it’s not listed at that link)?
I should add that I brought that roster into the discussion since I’ve found it very accurate and hope it potentially helps the original poster find some answers with his question.
That all said, I want to stress that I’ve made some big inferences with how I interpreted that data. Inferences which may or may not have any validity.
JayBee deleted his response. I’m curious what your thoughts on are on what I posted, since you clearly have some knowledge in this area (Which I don’t; I’ve just spent some time digging for information from sources that I consider generally reliable).
What I was going to comment on was that the merger between the BN Railroad and the AT&SF Railroad didn’t happen until December 31, 1996, following a final approval with conditions. The final approval was rendered on December 19th, 1996 with an effective date of December 30th, 1996. So that any SD70MAC locomotives delivered in 1996 would have been delivered to BN not BNSF, and any ordered and approved in 1996, should be considered as ordered by BN.
The BNSF merger is interesting in that the application was filed with the ICC, but the final approval came from the STB. Initial approval was given much earlier, but some of the conditions required negotiations which took time, so final approval wasn’t until the end of 1996.
The problem is the individual locomotive B/N within the order, the roster shows 9770 - 9775 as all 956615-54 when the individual locomotives should run through -59.
You didn’t comment on my posting that all SD70MACs delivered through the end of 1996, for a period of time belonged to BN before becoming BNSF even though they were lettered BNSF.
I had suspected that on paper Burlington Northern lasted past September 22nd 1995, so it was nice to see some confirmation. Definitely helps complicate matters though for the sort of question asked in this thread.
The SD70MAC roster shows correctly for me, btw. 9770 - 9775 don’t show as all being 956615-54 at my end. BNSF #9770 shows as 956615-54 with the builder number ascending for each subsequent unit to 956615-59 for the 59th locomotive in this order (BNSF #9775).
I wonder if there is more than one roster for BN locomotives on the Trainpix website. The one I am looking at has the heading “EMD SD70MAC locomotives 183 of 311 units” which caused me to scratch my head. Trainpix BN SD70MAC roster
Edit - your first link was to the Trainpix roster which has the issues, the roster on the Trainweb website is correct.
Thanx Leo (and others)! This should be helpful. I have to study this as it is very confusing. Does Trains Magazine have the “BN SD70MAC” list somewhere? I just hope to have the most “Accurate” information for my calendar description. If there is more I should know please help.
Poop, let me summarise the BN and AT&SF merger first. The holding corporations merged first on September 22nd, 1995. The Interstate Commerce Commision, which was the Federal Regulator for railroads was given an application by BNSF Corp, the holding company to merge the two railroads. At some point in time they gave a preliminary approval for the railroads to merge, but they stipulated a number of agreements that they company would have to finalize with other companies, before the actual merger could take place. This took time, and when they completed the conditions they had to submit those agreements, to the Surface Transportation Board(STB), which had replaced the ICC as the regulator of railroad matters. The STB completed its review of the agreements required and rendered it’s final approval for the merger to proceed on December 19th, 1996, but in their decision they held their permission in abeyance until December 30th, 1996. They may have done this in case of possible final legal challenges against the merger. BNSF consumated the merger on December 31st, 1996. So until that date, BN and AT&SF were separate railroads in fact and operationally.
What this means is that any SD70MAC locomotives delivered before that date were BN locomotives, which means that all SD70MAC locomotives numbered 9400 - 9499, and 9504 - 9775 were BN locomotives before they became BNSF locomotives, even if the locomotive was delivered lettered BNSF. It also probably means that SD70MAC locomotives numbered 9776 - 9837 were ordered by BN before the merger, even though they were not built or delivered until after the merger. But it is possible that the order wasn’t placed until after December 30th, 1996. The first locomotive of that batch was built in March 1997.
I don’t know how widespread the knowledge of EMD’s inquiry to order system is but I’ll describe it as I remember.
When a customer first starts talking with EMD about a potential sale, an inquiry number is taken out and it exists in EMD’s system with an I- prefix. At this point in time, the first two numbers are the year, the third number is a 6 for a new locomotive, a 7 for a rebuild order (LRO), and an 8 for an export. The last 3 numbers are a sequence number that resets (to 000 IIRC) at the start of a new year. So an order number such as 966706 would start out as I-966706. As it gets more firm, it transitions to Advance stage and gets an A- prefix, indicating it is likely to happen and settlement of details meetings start to be held with the buyer, then it gets an R- prefix for Reserve, at which point major items like engines and alternators are scheduled and long lead items like truck castings are ordered. Finally, when the order is signed, the production schedule is firmed up and all the parts are ordered based on their lead times re the production schedule. At this point the prefix is dropped from the order number. Especially for export orders, it may be several years after the inquiry number is pulled that it ships. (It’s possible I reversed the Advance and Reserve stages, it’s been a while.) There ar
I’m not so sure that we can yet say that 9776 -9837 were ordered or ever officially on the books of the Burlington Northern.
Doing some digging in articles from the mid 1990’s about the merger (Including some stories from Trains), it sure sounds to me like the merger was allowed as one of the final acts of the Interstate Commerce Commision in the late summer of 1995. A new company was formed as the Burlington Northern Santa Fe Corp, buying both railroads in the early Fall of 1995.
What happened afterwards appears to have been the official joining of the operating companies themselves, which appears to have been held up over a year by labor talks (No doubt about things like job protection, seniority lists, and other such typical concerns).
It seems clear with what bogie_engineer has told us that this order would’ve been post September 1995. So as I see it, it comes down to the question of who would be placing the order and officially owning the power during this transition period?
Would it be handled by what amounts to a holding company that owns both operating entities? Or would it be the responsibility of what by then was essentially a “paper corporation”, due to being the official operator of them (Since these were primarily meant for Powder River coal service)?
Leo, all you have to do is look at the never consumated sale of the line from Syracuse to the Canadian border by CSX to CN. The sale was approved by the STB subject to conditions, it turns out that CSX was unwilling to meet those conditions, so the sale never took place.
The BN and AT&SF merger had many conditions, most of them were met fairly quickly, but not all of them. The final condition was not met or at least settled until the STB dismissed further attempts by Oklahoma Gas & Electric(OG&E) for additional requirements concerning access by UP to its Red Rock, OK powerplant. The continuing dispute was over the charges to be levied by BNSF to UP for trains they would operated to the plant if they were to be awarded such contract by OG&E. The STB dismissed further conditions beyond those which BNSF had agreed to and allowed the merger to proceed. Until the BNSF met all conditions imposed upon it, it could not merge the two railroads, just like CSX could not sell the Syrcuse line until it met all conditions imposed upon it.
I don’t think the STB will oppose onerous conditions on the CP - KCS merger, but what if the STB approved the merger subject to CPKC selling the Meridian Speedway and the Dallas line to NS. The STB approved the merger, but I think CPKC might never happen. At the very least it would be delayed by protracted negotiations between NS and CP.
