What is the best way to clean DCC track? I have been told not to use Goo-Gone. I need some Ideas.
If you’re HO, then please use MAAS, a 2oz metal tube cleaner for $3.18 cents. Usually found in the house hold cleaning products section.
Also see www.maasinc.com
This prodeuct put my $99.99 Tony’s clean machine out of business and is up for sale.
MR also had a Jan 03 review on metal cleaners.
Fuuny, IMO, it’s the best and LHS haven’t picked up on it.
I have tried a lot of methods. Centerlines car works really well and so does Goo Gone. Goo gone is available in Wal mart and Ace hardware.
Why not Goo-Gone? Centerline recommends it for use in their track cleaners. I also use it (by hand) and it works fine.
John,
Dsose the goo gone mess up anything with DCC?
Some of teh people in my club have said it messed up their DCC. I have used it for the last three years and just installed DCC. Do you know of any issues?
Thanks
Mike
How are you using this product? My lay out is quit large and I would like to claen the track during operating sissions.
Thanks
Mike
There are many different cleaners.
The brite boys, the liquid ones, the paste and the car cleaners.
I have used rubbing alcohol @.79 cents a bottle,
denatured alcohol, nail polish remover, Wahl clipper
cleaner, QD aerosol electrical contact cleaner, goo gone and the most expensive, act-6006 at a buck an ounce.
Traded up from the $64.00 centerline car cleaner, www.centerline-products.com to the superior $99.00 Tony’s clean machine http://www.ttx-dcc.com/technews/clean_machine.htm
They ALL work.
I traded up to the clean machine because it’s the best but my layout isn’t that big. That was an over kill. I now regularly use the MAAS paste and park my Tony car on a siding. It’s now up for sale.
Some modlers use two centerlines as part of a work
track crew.
One for liquid application and the second for wiping.
You have a good selection available depending upon your requirements.
I run in DC, so I can’t speak for DCC (if there is any difference for track cleaning - seems odd if there is).
Maybe they ran their DCC loco’s before the solution dried and it caused a short? I’m just guessing as maybe DCC systems are more sensitive to these things?
I not DCC either and I will never know the answer but I have seen other forum members claim that products such as Act 3753 & 3003 by aero-locomotive works makes the following claim. "Recommended for enhancing ALL electrical contact areas, brushes,commutators, wheel & chassis wipers etc.
That would also apply after a track is cleaned by what ever product you first apply but comes at a stiff price. http://wwww.tttrains.com/aerocar/
A cheaper alternative that I picked up from Menards/home depot is , electrical grade, QD Contact Cleaner, a 11 ounce aerosol spray can for $5.00 bucks or so.
We all have to remember one important element;
no cleaner will prevent metal oxidation. It’s a natural chemical metal reaction. Preventive action will
slow it down and IMO MAAS coating fulfills that
requirement.
Mike The Goo Gone is the BEST product I have used for cleaning track. My Digitrax system works flawlessly and I attribute it to the Centerline car and Goo Gone. I run my cleaning car about once a month and have no problems with it. You may need to clean more often and since its so simple, I’d say once a week would be ideal.
John
Another product out there is called Flitz. It is a non-toxic metal polish. I bought a tube for my layout and I couldn’t believe the results! It’s been at least two months and I can’t see any oxidation or dirt build up yet.
Terry
i use the old centerline cars with the handi-wipes saturated with goo-gone. i use 4 cars,two with goo-gone and two dry. i pull them not pu***hem. if you keep rotating your cleaning cloth it will do a great job. the biggest mistake people make is not changing the cloth when it gets dirty. if you don’t it will lay the dirt back down. i have a medium size layout 17 by 22 feet and double decked. if you change the cloth reguarly your track will sparkle. i run dcc.
That Flitz, www.flitz-polish.com along with the Maas, www.maasinc.com were written up in MR Jan 03.
Here again it bears repeating: for N scale, because of the 4 to 4 1/2 oz loco weight, there will be slippage problems especially up a grade.
I’ve heard good things about Flitz too. I keep looking for it at my local Home Depot, but it’s never in stock (maybe there are a lot of other MRR’s in the area with the same idea?).
I’ll gladly give up Goo-Gone to keep the tracks cleaner for longer. As it is, I clean them by hand.
I use a Model Power cleaning car from time to time, and sometimes, when I really want to do some cleaning and good cloth was 99% rubbing alcohol[^]
I’ve heard that Goo Gone leaves a nasty residue that must itself be removed with alcohol. Personally, I have been using Radio Shack TV Tuner Cleaner and Lubricant with excellent results. But, I plan to Maas my layout before taking it to the Tallahassee Model Railroad Show on July 19th and see how that works.
I note yet another Atlas refugee on here, Welcome, Kent.[:o)]
Goo Gone is a multi purpose cleaner and as in the application of MAAS, requires clean cloth
wiping up.
Some liquid cleaners, Act 3003,3753, QD electrical contact cleaner & perhaps the radio shack
may leave residue that enhances electrical operation. This could be especially important to DCC
operations.
I have used the MAAS on loco wheels that haven’t been cleaned in 33 years. Woks for me.Meantime my .
Tony’s clean machine is out of work and seeking a new owner.
