'Track Cutters vs Dremmel Tool"
Hey everyone, I would like an opinion on this subject, would it be advisable to use good track cutters to make a good cut on your liftout bridge approach or is it best to just use a dremmel tool,?[*-)] Thanks N’ Take Care[8D] Trainsrme1
I prefer to use a Xuron track cutter, and finish the job with a file. I will use a dremel to cut and remove a piece of track already installed on the layout, with safety glasses of course [8D].
Simon
Always used a track cutter until my mentor got me a dremmel. The former is what I’m used to but the dremmel has more versatility. If you got the cutter, use it.
Hi Kasskaboose, I have two of them, thanks for the info, I feel now, I’m ahead of the game, tell me one of my pairs has a jagged blade is there a way to sharpen it?
I tried to dress and true up the cutting blades one time, but now I just use them for stripping insulation from fine wire.
I can add that I too use a Xuron rail cutter or an xacto saw with a track cutting jig. I have never used a cutoff wheel to cut rail while laying it.
Never use rail/track cutters on HARDEN WIRE/MUSIC WIRE. Use only cutters made for HARDEN/MUSIC WIRE.
I use the Xuron track cutter.
I’m with Rich. Clean cut every time. If you ever grenaded a cut off wheel, then you’ll know. During my working years, I used cutoff wheels all the time. Broke many of them and safety glasses would be very minimal protection. Our welder had a helmet that took a disc through it and gave him 70 stitches in his cheek to his ear. Just don’t take them lightly. Treat them with utmost respect.
Pete.
I too use a dremel With the right angle attachment so that I can get the cutting disc perpendicular to the rail
I am on the Dremel tool side. (Actually have two - one corded one cordless) Making cutting track a lot easier.
Only time I use a Dremel is if the track is already laid which is what you might want to do on a lift out bridge.
In my opinion, you use a Xuron tool to crop rail ends to length, ideally before the track is laid in place so you’re sure the cut is square both horizontally and vertically.
Only one side of a Xuron cut is clean and parallel. The other is wretchedly squashed, and would have to be filed smooth; the resulting equivalent of a ‘kerf’ would be indeterminately wide (and probably requiring a piece with proper ends to be spliced in somewhere). This is true of any similar design of end- or side-cutting plier or cutter; it is possible to design for minimum distortion, but the edges of the tool then become very thin and, at the required hardness, easily damaged.
The use of a Dremel (as opposed to something of smaller diameter like a Foredom or dental handpiece) is restricted by the diameter of the cutter – it must be of the same or greater diameter as the body of the tool if the cut in the rail is to be vertically parallel. I have seen people ‘cheat’ for cutouts by angling the tool as they make the cuts, so there are bevels at both ends of the takeout and the railhead is longer than the foot. If you’re using the usual Dremel cutoff-style wheel for thinnest possible kerf, the wheels are thin and extremely brittle and even the slightest twist or cock while the wheel is in the kerf will break or disintegrate it, so USE EYE AND HAND PROTECTION at least as religiously as you would with a Xuron – I use a face shield whenever I have to use one of those things. You can also now find larger-diameter diamond-loaded wheels cheap; the only issue is that these often have diamonds on their sides as well as edges so the kerf is wider and a bit more ragged than a fine-grit cemented disk.
The thing I used when lateral space permitted was a razor saw with very fine hardened teeth with zero ‘set’. You can make a guide that holds the blade upright and square or at a fixed angle, like a bottomless miter box, if your hand shakes. Very little dr
I use the Xuron to cut the track but to get the rail the precise length I need to splice in, I mark it with a hobby knife and cut it with a Dremel cut-off disc. The cut is a lot cleaner and needs very little dressing with a file. I’ve been doing this for nearly 30 years and still prefer this method after laying track on 3 layouts and have had to cut a lot of track.
I do all my Dremel cuts before the track goes down. There is an elbow attachment you can get for Dremels to get much closer if you need to cut already laid track. But so far, I haven’t needed to do that.
It’s a Xuron cutter for me. I only have a single Dremel, and that won’t give me a square cut on already laid track.
The Xuron is restricted to track. It doesn’t get used to cut wire or nails.
I use a Dremel with a flexible shaft attachment.
Paul
Yes, that’s what I do. I also use the thicker cutoff wheels. Makes the cutting process much more forgiving.
I use the Dremel diamond wheel’ one wheel will last years. Don’t use those cheap cutoff wheels that expload. I get perfect cut’s with the Dremel. So easy.
I use the Xuron unless the track is down and I need a gap, then I use the Dremal with or without the flex shaft.
One trick I was shown is if a Dremal cut gap is going to stand out in a photo, use hot glue (glue gun) in the gap and file to contour and then paint to match. It works great and makes it invisible.
‘Other’ methods are to file a section of sheet styrene to go in the gap or make old-school ‘body putty’ out of styrene sprues softened with solvent. (Likewise scraped and filed to shape and then painted to match the web.)
I have used Xuron rail cutters and they worked okay, but I have found that using a coping saw with a fine metal blade leaves the cuts very clean to the point where almost no dressing is required, and it doesn’t take very long.
Here is an example of rail gaps being cut with a coping saw before being dressed:
Obviously the coping saw can’t be used when the track is already installed. For that, I will use a diamond metal cutoff disc large enough to allow the Dremel to be held parallel to the rails.
Cheers!!
Dave
