Track Elevation Change Easements
A lot has been written about track easements coming in and out of curves. I haven’t found, however, articles or posts about track easements going into and out of an elevation change, e.g., going form 0% grade into a 2% grade. If no easement, the change is abrupt for locos and cars.
Can anyone refer me to an article/post on this topic or provide a formula or instructions for determining an elevation change easement? I’m modeling in N scale if that matters.
Thanks.
Yes, vertical transitions are needed. This topic comes up about every three months. Using the “search community” box to search for “vertical transition” yields a number of threads, probably the most recent is:
http://cs.trains.com/mrr/f/88/t/219308.aspx
In which I wrote:
cuyama
Thanks for re-posting the formula for calculating the effective grade on curves. I had forgotten the ratio.
Dave
Here’s a post from last year that includes the vertical transitions subject, in case any tidbits are useful in addition to what’s already been suggested:
http://cs.trains.com/mrr/f/11/t/203837.aspx
Use your longest cars to test for vertical movement of the couplers; you probably don’t want less than half of the coupler height to be engaged at any time, some couplers droop a bit and will make this worse too. If you don’t have any long cars, borrow a couple passenger cars or use it as an excuse to model your favorite passenger train and buy your own. :slight_smile:
I’ve found out over the years, cars that have the trucks set in from the ends behave differently than cars with trucks closer to the ends, if only your cars will be run on the grades, try several combinations. If others’ cars will be run, like on a modular layout, then try to guess the worst case scenario (two or three 89’ auto racks?). Passenger cars with touching diaphragms will have to be considered too, maybe a piece of clear styrene over the opening will prevent them from snagging on each other.
