I have searched all my old MRRs and cannot find a suitable track plan. I have a clear 20 foot wall but the layout cannot be more than 16 inches deep.
FWIW, it would be set in the 1949 era in the midwest.
Any such plans already designed?
Bruce,
Pardon me for stating the obvious…but have you tried the track plan database here in MRRs website? Another thing you might look at is big plans and see if you can ‘cut’ a section of one to suit your needs.
Just a couple of thoughts.
hi,
take a look at L-type switchers as well. Lance Mindheim’s East Rail layout, based on Miami, has two sections both 9 feet long; straightened out it would fill your bill.
Paul
In the original 101 Track Plans for Model Railroaders by Linn Westcott (MR), there is just such a plan that I have been looking at for many years thinking that it would be a good shelf layout to build. (I didn’t build it because I always had more room.)
The plan is called Port Ogden & Northern RR and is on page 6. It is 16 foot long and 1 foot wide. It has four different track levels on it, each 2 inches up from the other. There is also a 3D sketch of in in the book too, that shows it off really well with the suggested industries and bridges. It uses no.4 turnouts, but if you used no.6’s, it would extend to 20 foot long or so. By making it 16 inches wide, you would have more scenery and deeper industries. It’s HO scale.
Don’t know of a 20X1 that’s already designed unless Google shows something. However, you could probably adapt one of LM’s CSX South Florida layouts as mentioned above or put together some of David Barrow’s Cat Mountain dominoes together. You could also check some Yahoo groups on specific RRs like the Iowa Interstate for adaptable layouts. Just make sure you have a couple of runarounds so you don’t wind up with trapped engines.
I’d strongly suggest building the layout in sections in case you ever need to move it.
Another thought - prototype RRs tend to be long, linear things. Maybe if you checked a few proto track charts, you could find a small section to model.
PDF-download = Shelf layouts you can build.
Just curious - why not just design a track plan from scratch, based on what you want on your layout?
The midwest covers a lot of ground - from very urban to very rural, from single track branch line with one train a day to fairly busy junction town.
What is it that you want on your layout?
If youi just want to copy an existing track plan, why not just cut out a 20-foot length e.g. of Michael Maas’ “South Central Minnesota Railroad” from Nov 2005 MR (and 102 track plans): http://mrr.trains.com/How%20To/Track%20Plan%20Database/2007/08/South%20Central%20Minnesota%20RR.aspx
Or say Walker and Bemidji from the Minnesota & International from the Jan 2006 MR (and 102 track plans): http://mrr.trains.com/How%20To/Track%20Plan%20Database/2007/08/South%20Central%20Minnesota%20RR.aspx
Or a piece of the Soo Line plan from the June 2008 MR: http://mrr.trains.com/How%20To/Track%20Plan%20Database/2008/04/Soo%20Line.aspx
Or some parts of the Wisconsin and Southern Troy branch expension from the Model Railroader company layout in the Jan 2008 model railroader: http://mr
