Track Wiring
Should one use solid or braided copper wire for outdoor track wiring? I am using a Bridgewerks 10 amp power supply for track power.
You can mix and match if want, both will corrode if you don’t soulder the joint’s or use wire nut’s.
Dave
This is what I was told, It was better to use braided wire than solid, The reason is if you break the solid wire then you lose power, If you break a few braided wire you still have many more wires to send the power to the track, also the braided wire will flex better than the solid and this will make it easy to work with. But both are good!
