Just installed and wired up my first Peco HO #6 electrofrog left turnout. The mainline runs through this turnout when switched to the left trun. Why are my ScaleTrains 6-axel engines derailing when it hits the frog? My Broadway 4-axel switcher runs through the turnout just fine as does my 4-6-2 stream.
What appears to be happening is when the leading 3-axel truck enters the frog where the guardrail is (on the left side) and the plastic center area (on the right), the leading truck seems to pull slightly to the right and derails as it goes through the frog. It appears this plastic “X” in the center of the frog is raised up making the wheels to come up and off the rail.
(If I knew how to add a photo I would, but haven’t figured out how to get it to work)
aa) which way are you describing; e.g., loco entering from points end, turnout set straight ahead (or left)?
a) do multiple locos do this? cab forward as well as in reverse?
b) do you have a NMRA gage? If so, confirm the depth is ok for flange clearance at the offending spot. (I had some Atlas crossings where the depth was insufficient for at least one loco, so i filed the groove deeper.)
c) If not all those locos, check that the wheelset gauge is spot on. I would be shocked if the (RP-25, I presume) wheel flange depth were excessive.
d) confirm the turnout is nice and flat (not twisted)
e) do you have other Peco EF’s that have the same symptoms with this (these) locos?
Check your loco going in the opposite direction facing both ways. If it is only facing one way and one direction that it derails then check the gauge.
I only have one 6 axle loco as well as a couple of 0-8-0’s but heading into a curve, the leading edge of some of the guard rails on Peco turnouts can be a tripping point which can be fixed (in my case) by bending that leading guard rail inwards very slightly or trimming the plastic so that the lead wheel does not pick that corner.
It’s a problem either with the gauge, with the trail, or with the thickness/profile of the wheels that aren’t making it through the frog area. The PECO turnouts are high quality, very reliable, and I have no troulble with any of mine using a wide variety of locomotives from several different importers. If I ever do, I blame the locomotive first.
You can critically check gauge of all axles. Then, look at the trail. Like below:
Both axles the same length, both pairs of wheels in gauge, but the trail…
Also, and it would be the least likely by a country mile, the flange on one wheel might be thicker than the other wheel’s.
The loco is entering from the points and turning left. Going straight it often derails as well. Tested at different speeds and directions. Perfroms a little better coming from the oppsite direction.
Seems it’s happening to my 6-axel Scaletrain locos. Cab forward & cab reverse.
I have the NMRA gage and will check that out.
Turnout is as flat as I could make it. There is no bow in it.
I do have several other Peco EF but are not installed yet. This was the first and I am testing all track and connections for smooth running. Have had to do some filing at a few joiners. These Scaletrains are the only locos where I’m seeing derailing issues.
As Crandall points out, (pardon the pun) Peco are very well engineered. From what you are describing however, the problem could be in the movable rail trying to “straighten” itself however microscopically after having been bent and that has been another issue I have had to deal with with extreme conditions in my shed. I think it is due to a very small degree of elastic memory in the rail being bent by machine.
In short, check the gauge of the track first right the way along the turnout , holding the moving rails with your fingers and very carefully flex that rail outwards but not too far as this is an area where your wheels can be tripped before hitting the frog. This should give you literally that zipteenth difference in gauge that may allow the truck to go through freely!
Not Peco, but every loco that had issues with the #6 Atlas turnouts 2 layouts ago ALWAYS was traced to the loco wheels not being properly gauged. Definitely get an NMRA gauge if you don’t have one and check these things. Most drive mechanisms these days easily allow the wheels to be adjusted slightly wider or slightly narrower as needed.
Certain Athearn blue box 6 axle engines also seemed to have difficulties with certain turnouts - the SD45 and the FM Trainmaster come to mind. I think the answer had something to do with that metal strip that was part of Athearn’s electrical connection system back then interfering with the sideways movement of the engine’s trucks.
There have always been some combinations of track and trucks/wheels that just did not seem to work, regardless of NMRA standards being met.
I know that Atlas has had problems not with the frog height, but with the material at the base of the frog, which can lift the wheel up. Althought I think that usually is a bounce rather than a derailment.
So the mainline is the diverging (left) side of the turnout?
And, the derailment results in the loco going towards the straight route when the points are thrown to the diverging route?
What turnout control are you using: manual or remote; PECO, Tortise?
After getting the NMRA gage check the flange depth of the wheels. I would be surprised if a Scale Trains unit would not have RP-23 compatible wheels.
As has been mentioned, truck swing or lack there of, might be the problem.
This would show up if you run the suspect loco head-end first or tail-end first over the same track arrangement.
If the derailment only happens when it is “facing” in one direction it’s probably the loco.
You mentioned that the loco “lifts up” off the rails…
Could this be happening from some part of the belly of the loco hitting on another part of the turnout?
I had to shave down the bottom of a Bachmann USRA 0-6-0 gearbox cover because it couldn’t clear the re-railers and would derail on straight track.
You could have gotten a faulty turnout; the frog or “X” section as you described, might be not deep enough to allow the flanges to pass over without interruption.
On the NMRA gage there are three track measurement options. One is labeled “Flangeways” with two points protruding from the gage.
The points on the gage should fit into the frog and rest on the top of the frog. If there is a gap the frog is too shallow.
Don’t just look at the turnout, but also the tracks on either side. A small difference in slope from the approach track could make the locomotive tilt slightly, lifting the front wheels up as it approaches the turnout.
Make sure the entire approach to the turnout is flat. The turnout itself is not enough.
Peco Electrofrogs do NOT have a plastic insert in the frog - all metal but Insulfrog turnouts do & they may cause wheels to rise a bit but it has been known that some power bogies will turn enough one way but not the other and then only when moving in one direction.
Ah ha, now I see what you mean by the plastic X piece - that is part of the moulding and if your wheels are rising, it means the wheel flanges are too big - normally Code 100 track will take a large range of wheels but Code 75 - - most modern rolling stock with RP25 wheels works OK but not those with large flanges.
After you’ve checked the wheels out thoroughly (in gauge, flanges are proper contour and properly formed, meaning round and no discontinuities in the bead or the flange) and made sure nothing on the loco is hanging up and forcing the trucks off the rails, focus on the turnout.
Even a high quality product line such as Peco can produce an out-of-spec product on occasion. Perhaps a part did not sit in the assembly jig quite properly and was undetected at the time. It happens.
Something else about commercial turnouts - none of them conform completely to the NMRA turnout standards. Often flangeways at guardrails are a bit wider than recommended to handle stock with thicker-than-RP25 flanges, for example. So check the guard rail flangeways. You might solve your problem by gluing a thin strip of styrene against the inside face of the guardrail, if the flangeways are too wide. That would be pretty careful work, but it may solve your problem.
Or you might just replace the turnout and see if that does it.
EDIT: I made the following comment presuming a plastic frog black part. If metal, would be tougher, plus you would want to paint the cut black again. Are you sure you diagnosed this correctly; i.e., it is insufficient frog depth, not flangeway gage or width or excessive wheel flange diameter?
You can use a needle file to deepen the groves between the frog rails and guard rails. Before you do that, suggest you put the NRMA gage flangeways tabs there (with a flashlight behind it) and attempt to eyeball how much depth clearance exists. Then compare that with your other PECO turnouts to guestimate whether they will have the same problem. Don’t know whether that is workable.
Additionally, I understand that you can see the loco wheel rise upon entering the frog. Visually note how much it rises, as a bit more than that would need to be filed away.
Try these tests with another turnout, uninstalled, to understand whether to expect this problem with others.
