Following in 3985’s footsteps…
https://www.youtube.com/watch?v=icgH_3dXdOU
You may want to scroll past some of the footage, but you’ll enjoy the rest! Note the method used for slip recovery…
I wonder if it was a stalled manifest, or a “stalled” manifest.
PS have to love the shifted load at 8:30. Going to need a buffer if it moves any more.
At least when I was working for CSX - when one train was required to assist a preceding train. The train the was doing the assisting was to secure their train, cut away from it and then do the assisting. I guess UP has different rules.
The location for the start of the push might not been the best. However the quality of the video will surpass any of a big boy doing what it was intended to do. Question-- The diesel did not seem to be helping?
844 helped a stalled freight back in 1996. It also did not have to cut off from its train, so BaltACD is correct.
To complete the trifecta, here is 3985 pulling 143 wells of doublestacked containers.
Trains stalling on Blair is not unusual. I’ve stalled there and I’ve shoved Trains over that have stalled. Either a train has engine problems or a combination of too much train, not enough engines and bad rail conditions.
Normally engines cut away from their Trains to shove another one. I know some, now retired, who would bring their train with them. The rules don’t really address one train helping another, just the cutting in and out of manned helpers. Having to cut out the automatic brake on the helper makes it impractical to take the train with them. Those old retired guys normally didn’t cut in the air, just knuckled in and shoved. I’ve only seen bits and pieces of the video, but I kind of think they just coupled in and shoved.
The steam crew being there own little department, they may be able to do things a little different than the rest of us.
Jeff
This one just looks a little too convenient.
Either way, it got a lot of coverage.
The short, light steam special would make an ideal helper compared to other trains. Perhaps they deliberately ran it behind a freight that would likely have problems?
Here’s the freight train that was pushed. The second unit is a BNSF ES44C4, the uploader says it was dead but some other comments indicate it was just autostopped.
Tell me what notch 4015 was in the whole time it was passing the camera, and 4014’s forward engine was slipping…
I confess the thing that shot immediately to my mind was when the donated Space Shuttle was being moved by road, and they cut the tractor off and substituted a Toyota pickup truck. Strangely, I never saw the obvious (and it would have been impressive even to me, who knows better) ad appear afterward, either in print or on TV…
MCHNP 28, 146 cars 9505 trailing tons (doesn’t include the dead engine) 10052 feet long. Two engines UP 5729 12.1 EPA (Equivalent Powered Axle), BNSF 4264 DB (dead bad). Dead bad is a status, it doesn’t neccesarily mean it’s dead. It just has a defect that doesn’t allow it to produce power.
TPA (Tons Per Axle) limit for Blair for manifests is 430, for an engine failure 457. Divide tonnage (9505 + about 200 +/- tons for the dead engine, 9705 tons) by TPA (430) means it should have EPA of 22.6. Using the eng failure TPA (457) still needs 21.3 EPA. It was a definite candidate for stalling.
The grade on Blair hill is 1 % on the east side, where this takes place. Theres a few curves and a permanent 40 mph beginning at the Missouri River bridge on the Iowa side to about 1/2 way through Blair. Where there’s a permanent 45 to just a bit west of the crossing shown in the video.
An intentional setup? Probably not. They do gamble on underpowered trains making it. I know that from experience, both making it and not making it. And under the right conditions, a train over on TPA can make it. (This was probably a big gamble, but they’ve done it before.) Other times a train at or under TPA will stall.
Jeff
When the diesel in 4014’s consist rolled past it sounded to my admittedly inexpert ears like it was idling and not doing any of the work. I’m guessing the push was all 4014.
I heard pretty much the same on a video of CNJ #113 excursion in PA. With nowhere to turn the train or switch ends on the consist there was an RBM&N diesel on the trailing end of the passenger consist, one pulled out and one pulled back. The diesel had that idling sound on the steam pull-out.
Anyway here it is. See what you think. By the way, CNJ #113 is the only operating Jersey Central steam locomotive out there.
On my territory when I was working, there were a couple of grades that ‘over tonnage’ trains could routinely conquer the grade - If they were long enough - if they were long enough, they never had their total tonnage on the grade, they could have a thousand or more tons on the completed side of the grade before the last of the train got on the grade. A train with the same power and tonnage but a thousand or fifteen hundred feet shorter was dead meat on the grade, because ALL the tonnage was actually on the grade.</
