I hope you enjoy this, I found a unqiue way to make trees by the dozen. Take cotton balls and spray them green, stick them on a tooth pick and stick them on the layout.
Check out Al Skinner’s “how to” article “Trees by the bucket” p56-57 MR February 2008. Here is a vey simple (fairly inexpensive) method of creating a hillside forest. Note the rock outcrops and dead trees. I prefer my furnace filter method, for making trees with visible trunks. Note that the Woodland Scenic foliage clumps also come in Fall colored clumps, so one can have a forest’s colors change with the seasons, with Summer or Fall trees on removable foam hillsides. Commercial deciduous trees are available at most LHS, but if quantities of trees are desired, they are far too expensive. I assume that the “cotton ball trees” are for an N scale layout. I have an HO layout, and have tried cotton balls, clothes dryer filter fuzz, and ended up using furnaace filters. The cheap blue colored fibrous furnace filters are actually somewhat like Oreo cookies. I just finished making 280 deciduous trees for woodland areas on our Historical Museum HO layout. Meat skewers cut in half and sharpened on both ends are stained in bulk, and dried. I found that making 30-36 trees at a time, required somethiing like 6 hrs. of work to turn out 280 trees. Press the stained, half skewers into holes drilled into 3 inch deep insulation,(for a firm holder with the lowest layer of foliage on the insulation surface.) I cut rough circles from furnace filters (spray painted flat black). Single circles pull apart into three circular layers. Press the center of the circle onto the skewer (down to the insulation). Squeeze a circle of Elmer’s glue onto the circle (about 1/4" from the edge). Sprinkle on ground up ( in a coffee grinder) Woodland Scenics (3 green color foam clumps). Repeat, using various size filter circles, with a clump of foliage glued to the top. Rail cutters can be used to nip off skewers, at various heights. Pre-stain tapered insulation strips,or ova
Hot melt glue from one of those glue guns. Cools rather quickly and will help support. Not recommended for very large trees, but we’re not talking about those here.
I just don’t know what this hobby is coming to, most modelers just can’t afford to be that precise with detail, better come up with something a little more economical.
I have a friend that made pine trees from bumpy chinille (sp?) - hundreds of them . . . . they started to dissappear from his rr. It turned out that mouse was harvesting them to build a nest under the rr.
loathar. those dust bunnies from under the layout should make good brush. Also spray painted dandelions will work well too. Nice little tree,no expensive toothpick needed.
My glue gun has become one of my most valuable tools. I had it for years but was apprehensive about using it, probably because of the lack of success I had with tools like an airbrush and soldering iron. I figured it would be one more thing to make me feel stupid because I couldn’t learn to use it right. As it turned out, it was amazingly easy to learn to use effectively. I’ve used it for a number of different applications. I especially like for forming cardboard strip framework for my hills and mountains. Eventually, I did learn to become moderately skilled with the soldering iron. Still haven’t figure out the airbrush.
