I’ve just spent an afternoon troubleshooting a problem with a peco three way turnout and learnt a valuable lesson. Several of my locos were stopping as they passed over the right leg of a peco threeway turnout. It’s been part of my layout for over a year now and just started to give trouble recently and was gettig worse. I decided to fix the problem and make the turnout more DCC friendly at the same time.
When I installed it I had set up the 3 frogs to be powered from the two sets of tortoise contacts so I assumed that the stopping was caused by the switch blades not making good contact with the stock rails (this has happened to me on normal left and right handed turnouts). I wired the switch rails to the stock rails, but this didn’t fix the problem. I was perplexed! When I used a test lamp to check the power, it all looked perfect.
But I wasn’t putting the test lamp between the right stock rail of the turnout and the left switch rails, frog and associated left rails of the turnout. I used the right rail a bit further down the track.
The fault was that the rail joiner on the stock rail was not making good electrical contact with the rest of the track and because of the track configuration, there was a gap in the right rail at the other end of the turnout so no power was getting to the right stock rail.
I should never have problem with this 3way turnout now it is soldered to the other rails and the switch rails connected to the stock rail. We live and learn. I’m 64 and didn’t think I’d fall for one of the oldest tricks in the book.
Thanks for sharing your experience. It reinforces my commitment to attaching a feeder to every piece of rail and to putting jumpers between the point rails and the closure rails. My layout is not built yet but I have all the turnouts already and they have been modified as per Allan Gartner’s recommendations:
You might. Have you put fingernail polish on the frogs?
No, it’s not like putting lipstick on a pig. Peco frogs are plastic, but where the rails come together at a V, the gap between the rails is very small. Most of the time, there’s no problem, but sometimes engines with wide wheel tread will bridge the gap between those two hot rails, which are oppositely polarized, and cause a short. The solution is to insulate just a quarter-inch or so of that V, so wheels passing over don’t make contact with both rails. My insulator-of-choice is black nail polish. I’ve put it on each of my Peco turnouts and never had to do it again.
Yeah, the frogs on Peco Insulfrogs are plastic, but the frogs on Electrofrogs are metal.
I wouldn’t solder every rail joiner on the layout because you need room for expansion and contraction.
Adding feeders to every rail joiner is no guarantee. Every once in a while, a loco will come to a halt on my layout. I wind up sliding the rail joiner back and forth to re-establish power to a dead section of track. And, every once in a while, that rail joiner has a feeder wire attached to it.
How much does the temperature vary in your train room? Mine never goes below 60F or above 80F. I’ve soldered all the joints, and left the block gaps with no insulating joiner, just spiked them well. If you have your road in a space that’s not heated/cooled such as a garage, it’s likely to be more of a problem, but it hasn’t been an issue for me.
I prefer to run a wire across the joint rather than solder the fishplate/rail joiner. I haven’t had any problems with expansion with this layout as it is in a spare room that is lined. I live in Brisbane Australia which has a semi tropical climate, no snow, but it can get very hot. Thanks for your suggestions.
Rich. I would think the expansion and contraction issue could be handled by unsoldered joints somewhere else near the turnout. A section of straight track(s) nearest the turnout could be the designated “horizontal shock absorber”, allowing the OP to solder a feeder to each leg of the turnout.
Code 100 N/S rail expands only 0.25" (6mm) over a contiguous 100’ with a rise in 30 deg F. The smaller rail lengths in a typical commercial turnout should not be significantly affected by large swings in temperature. There is no practical need, or worry worth losing sleep over, to solder anything except feeders in turnouts.
Most closing gaps outside of turnouts are due to reductions in ambient humidity, causing a commensurate shrinkage in the roadbed and supporting wooden dimensional lumber comprising most frameworks for layouts. That shrinkage across the grain as wood dries seasonally brings any rail ends at gaps closer together. Unless fixed hard in place by very strong adhesives, turnouts should not be affected by this.
Gonna somewhat highjack this thread for a turnout issue [oX)] I bought a new rh #5 electrofrog turnout sealed in the box and installed it without issue but when I switch to the right hand turnout it shorts my DC track. It works good on mainline. I don’t have any track attached to the turnout and I cannot see any reason why it would short. Any suggestions appreciated.
BTW, it’s a Peco turnout and my DC power is soldered to the rails about 1 foot past the turnout and the track is just an oval with no other turnouts or slips, etc…
OK. You have to have some, so I’m guessing you have the track through the straight leg, but none on the diverging leg. I’ll also assume that the switch is receiving power from trailing point side as well as the facing point side. In that case, if you didn’t gap the frog rails, you’ll get a short every time. Gap both frog rails your problem will go away. On electrofrogs, the points, closure rails, frog, and frog rails are all electrically connected. Throwing the switch allows power to travel from the straight side frog rail, through the frog, diverging closure rail, and diverging point to the opposite rail.
I insulated the mainline frog and it did the trick. I pulled out my multimeter and tested it all out to see the electron flow. Thanks for the help from a lurker that finally decided to sign up.
Yep, there are a number of references to insulated (insulating) rail joiners in the instruction sheet for the Electrofrog.
My understanding is that in DC, the inner frog rails are sometimes not gapped, leaving the divergent rails with the same polarity when the point rails are switched to the mainline. The idea there is to “park” locomotives on the siding so that they cannot move untintil the point rails are thrown divergent once again.
