Which switch should I use for n scale?
I plan to have a short wire run from the turnout to the edge of the layout so that the switch for the turnout control will be directly in front of the turnout.
Atlas switches are good for N scale. You will need to file the points for a tight fit though. I have had problems with the train derailing because the points were to thick at the ends.
The Lone Geep
I think you are asking about what type electrical switch you need to control your turnouts. Depends on the type switch machine you use. Atlas’ need a momentary contact, not sure about Peco or Tortoise,
Good luck,
Richard
