I am converting a Geiger HO turntable to use in my S layout. The motor for the turntable requires a 12 volt DC power supply, but no other details are included in the instructions.
I have looked at HO transformers, which are primarily DC voltage, but that seems like it might be overkill. I have also looked at 12 volt DC power supplies/transformers, will these work for what I need?
The MA rating on these seem to range from 200 to 800 and then on to 5 Amps or more as the price increases, but I have no idea how that relates to what I need. I pasted an example below, this one is 12 VDC 500 MA.
Assuming that the turntable is electrically no more complicated than a DC motor, you should be able to make DC from your transformer (or another) using a bridge rectifier. Then you will be able to control the turntable’s speed.
Hi, thanks for the response. I actually thought about that but kind of figured it would be easier to just go with a seperate power suply for the turntable.
The turntable has controls for CW & CCW rotation, an auto setting for indexed stops, and a momentary switch for manual rotation.
I will look into a bridge rectifier, but I am still interested in determining whether or not the kind of power supply I included in my original post has enough power to run a 12 volt DC can motor.
