I was traveling on I-44 in MO where the BNSF line runs along the highway. I saw a unit train of 50’ low side gondolas. This struck me as odd, and I had never seen 50 or more gondolas in a unit train before. What would this kind of train be used for? I could not determine if there was a load or not, I was driving. The train did not seem to be a work train, although it could have been. The reporting marks were not all the same and seemed to be private company’s that I did not recognize.
Probably fracking sand to be used in horizontal drilling to extract needed oil or natural gas. Either under load or returning for more sand empty.
This whole horizontal drilling thing has created a boom. For ordinary folks and the railroads. A 20 year old with a high school education can make $80,000/year in the oil fields. The railroads haul sand in and empties out. They then haul oil out and empty tank cars in. Can’t beat it with a stick.
CSX/BNSF are running trains of haz mat sludge from Hudson River to Oklahoma. This typically has been moving thru Chicago, but perhaps routing was changed due to the congestion in Chicago.
It would work as the Frisco line is not as busy and the St. Louis line for CSX is not nearly as busy as the Chicago line.
In the east, unit trains of mill gons are slab steel trains, taking steel made at one mill to another to be finished by rolling into sheet, structural shapes or pipe.
Frac sand moves in low sided gons? I would think covered hoppers…or even open top hoppers.
Fracking sand is precious and cannot be wetted down in transit nor given to the wind from open top cars so would not be in low side gons or hoppers. Thus fracking sand would be in covered hoppers. And because it is a mineral product with little value, it would have to be in larger cars than open hoppers or gons. What’s in the gons? Probably scrap metal or metal coils.
Something like this? This train had dried mud with PCB’s extracted from the Hudson River near Port Edward, New York. I filmed it near Cameron, Illinois entering the ex-Santa Fe Transcon last August 24. It was enroute to Avard, Oklahoma.
There are numerous metal products that move in unit open gon trains. Coiled metal normally travels in ‘coil gons’; specially equipped gons that have cradles for the coils and are covered to keep the weather out.
In sizing cars for bulk anything the issue is density. In the covered hopper world, since sand is relatively heavy per unit of volume it moves in small cube cars while plastic, which is relatively light moves in high cube cars, holding weight capacity of the cars constant.
Crushed rock is often shipped in gons. The KCS regularly delivers unit trains of rock to a transload facility near my home. The gons are unloaded by backhoes which run on top of the sides of the cars to transfer the rock to trucks waiting alongside the train.
A lot of ‘frac sand’ is initially moved in 50’ gondolas. The UP moved out a unit train at Winona, MN every week. IIRC, the train then moved to a washing/grading plant where the actual frac sand is loaded on 100 ton capacity covered gons for final delivery to Texas. The DM&E(CP) moves clay east in 50’ gondolas as well. Not sure where the final destination is.for the clay.
If the mine/mines are producing 7-10 trains/week, many times there will be a large plant to wash or sort the sand and load covered hoppers. There are quite a few of those in Western Wisconsin.
Fracking Sand Products are not normally a placarded product… So identification of their contents may not normally be noted on the exterior of the cars… It used to be an identifier for certain types of cars in what would be considered a ‘dedicated service’ to be stenciled with a notation to return that specific car to a terminal location for reloading. NOt sure if that practice is still followed?
In this area, we have more of less a junction(s?) of BNSF’s Southern Transcon and a line coming from Oklahoma, and Texas(BNSF’s Ark City Sub) areas.
There is a heavy presence of smaller covered cylindrical hopper cars ( denoted by two drop doors). This type of car would be used heavier weigh and smaller volume loadings. Like Bulk Cement or Sand and of course the larger cars with four drop doors ( used for lighter volume products,Grain,Plastic pellets,etc.).
Southeastern Kansas produces a lot of Bulk Cement at a number of locations; the rest of the State is of course origin for lots of grains. Regulars around here, are long strings of smaller hopper cars, Sand(?), Loaded going Northward, and empty going South… Just some non-scientific observations of an interested party. It does seem like there is a lot of this activity,though.
Noted in the video - the loads are tarped, and there appeared to be weed stalks sticking out from under one of the tarps close to the front of the train. I’d go with the contaminated river sludge - tarped to keep from spreading PCBs all over the countryside.
No good reason to tarp raw sand - and it’s hardly a placarded product. (Been to a beach lately?)
But it does explain how and why fracking sand is handled in transportation: kept dry and separate from the elements, in hoppers so that it doesn’t blow away, that is not just sand but a processed and thus a more valuable product than beach or construction sands. I didn’t bring the subject up but just explained why it is so handled.
Nice try, Phoebe, but first you’ve got to get Obama’s EPA – which has been trying as hard as it can – to find water poisoning as a result of fracking. It hasn’t been able to do so. The elementary fact: The fracking cocktail is injected deep into the ground, far below the acquifers and surface water from which most of us drink.
You’d need a very long straw – and a strong impulse for self-destruction – to hurt yourself. (Or maybe you only want to stampede public policy?)
The Trains May 2013 issue has an article on frac sand, and they state that raw sand is transported in open gondolas, and processed sand is transported in covered hoppers. BNSF hauls frac sand from mines in Illinois and Minnesota to Texas. A train from IL could travel along that ex-Frisco route. The article shows a photo of a BNSF powered train hauling a unit train of frac sand in open top gondolas on page 52.
Back in the early to mid 1990s Southern Pacific hauled a lot of copper concentrate from the Bingham Canyon mine in Utah to Coos Bay OR to be loaded on a ship for export. Most of this was in open gondolas; sometimes as blocks in general freight trains and sometimes as a relatively short unit train.
I remember seeing an article on how the sand used for fracking was being transported in large sacks that where loaded on boxcars before they started using covered hoppers.
