UP Brazos river bridge flood damage & repair
Any pictures or reports on the bridge. The UP has not updated their web site with more info. Other sites say one pier has major shift or pier may have even sunk ? Sunset limited will be cancelled SAS <> NOL until bridge fixed and freight back up cleared.
http://www.up.com/customers/announcements/customernews/generalannouncements/CN2016-14.html
Found a bunch of before and after pictures. Does appear one pier underscored ? Maybe pier was on wooden pilings ? MC any thoughts ?
https://swrails.com/2016/06/07/up-brazos-river-bridge-woes/
The pier foundation may have been a spread footing rather than piles. While current practice usually calls for piles, that was not always the case a century or more ago. The railroads will routinely monitor the footing conditions, either with divers or at low water levels, but very occasionally extreme and prolonged flood conditions can cause rapid deterioration.
It seems that the settlement of the pier was found by a watchman or patrol, rather than a train, a sign of safe railroad management.
John
Vermont Rail Systems’ White River Bridge in White River Jct. VT was damaged in 2011 during tropical storm Irene when the south pier shifted in moving water. The masonry pier dated to the 1880s and was set on “ledge” but not anchored to it. The new pier installed by the State of Vermont - the line’s actual owner - is well and truly anchored, while the original north pier is still in use.
About this same time of year; it was 2010 [June 10th] Kansas had been in the throws of some very heavy rainfall, and a similar bridge pier issue occurred here in Kansas. The location was on the Chikaskia River Bridge, just north of Caldwell,Kansas. This line is currently the UPRR’s OKT sub, but was originally the Rock Island RR, south of Wichita.
The photos in the linked article are of UP train that was stopped out on this bridge, it was a alert engineer who saw a problem, put the train in emergency, got it stopped before it went off the bridge.
Link/Photos @ http://www.gordon-elias.com/blog/840/union-pacific-train-removed-from-sagging-bridge-in-caldwell-kansas/
The train was later that day backed off the bridge successfully, and it was determined that the pier had been a victim of scouring in the high water.
The Brazos River bridge is on the original GH&SA ‘Sunset’ route between Houston and San Antonio, now part of the UP Glidden Sub. It is a single-track bridge, also used by KCS and BNSF, and Amtrak Trains 1&2. It is the most direct route into Houston from the west, and has a lot of traffic, including many UP and KCS container trains.
The east pier of the truss bridge was originally on the east bank of the Brazos, and is now in the river and is sinking. The approach off the east bank is standing, but is also now in the river. The Brazos began to wash out the east bank when the river level got to 50’ or so and kept rising to about 54’ (normal is about 14’.) A huge volume of floodwater has been coming downstream for about a week. It may still be another week or so before the water level comes down enough to begin repairs, and will probably require a huge amount of fill, if it’s possible to re-route the river back to its original course. Going to be a lot of work.
The Brazos river Bridge is right next to Highway 90A, just east of Richmond Texas, you can see the bridge from most of the town, so once it began to sag, everyone in town would have noticed…like Sugarland, which is a few miles closer to Houston, Richmond is a railroad town, build around the tracks.
With the detour off the Glidden Sub, traffic here at the Port is showing up in short burst.
Video of night time work. Look closely a pile driver and very large crane. Maybe crane will pick up end of bridge as pile driver installs new piles for bridge bents ?
https://swrails.com/2016/06/10/brazos-river-bridge-repairs-june-9/
Looks like the flooding ‘floated’ the approach bents above the level of the bridge proper.
Bridge contractor and Uncle Pete’s bridge engineers in Omaha have probably put in some long nights on this and have dug up all the history they can on the thing. The local geology is going to be the driving force on what happens here. The H-Pile approach bents, I suspect, are fine and the old concrete and stone abutments on reed matts are finished. The diver, who looked at scour probably did the job totally by feel/touch (scary in that turbid water, if it was even safe to enter)…If there is zero piling in the old concrete bent, expect helper pile to be diven to support the two spans on either side of the failed bent supports, support the two structures and then put the track back into service. Then UP will look at its options, including the demo of the old structure and driving a new pile bent. No two bridge solutions are ever the same. A big part of the future is the status, clearances and load carrying capability of the existing steel truss for future 286K-315K loading. Some value engineering exercises are in order. (PDN?)
Wonder if this one will be a future AREMA presentation/discussion?
The red machine is a lattice boom crane,probably a Manitowoc from the color. The white machine is a hydraulic crane, necessary to assemble the bigger machine. Any dedicated pile drivers are likely in museums. Either of those machines can drive piles with a pile lead and hammer.
It will be interesting to see how this plays out. Before the recent downturn UP was extending the second MT west from Houston to (possibly Tower 17 in) Rosenberg. This would require a new bridge; looks like it might need to be higher than the existing one.
Reminds me a lot of the summer of 1993. Had a similar occurance on one of our bridges in MO. Water undermined the pier in an approach span and dropped the pier. Had to drive new pile around it to bring the spans back up.
Something similar will probably be done here. Looks like a good case study to update AREMA’s Bridge Inspection class segment on Scour. This is a classic “Fix the River” scenario. In the video, see how much of the bank has been cut away because the river is moving towards that bank. Only effective way to respond to that is to place control structures on the outside of the bend in the river to push it back to where it came from.
Here’s a shot I took of a train going over the bridge from a couple months ago when the river was at a more normal height (now imagine it about 3 ft from the deck of the bridge!).
I took the shot from the east bank of the river; the pier that sank is out of frame to right about 100 ft or so (it’s the opposite of the pier to the far left in the image). As you can see the pier is not normally in the water, and the ground beneath - which is a soft clay - likely just washed away in the flooding (which peaked at a flow rate of about 100,000 ft3/s, a tad bit above the normal 7,000 ft3/s).
As an interesting note, about a week before the bridge at the Brazos was taken out of service UP had just put into service a new 10-mile stretch of 2MT between Missouri City (on Houston’s southwest side) and Sugar Land, about 5 miles east of the Brazos River bridge.
Other than extending that another two miles to Harlem (the next siding two miles to the west of Sugar Land), I doubt UP is going to add any more 2MT to the Glidden Subdivision anytime soon due to the ROW restrictions in Richmond and the Brazos River bridge.
Also, in regards to the Sunset Limited, today it seems Amtrak finally figured out a reroute plan to get around the bridge. Yesterday morning Train #2 (eastbound) used the BNSF Galveston & Mykawa Subdivisions to get to Houston, leaving the UP at Rosenberg (just west of Richmond) and taking the BNSF southeast to Alvin (25 miles south of Houston), where the train then shot north up to Houston. Once in Houston, the train returned to
great pictures !!! thanks !
The reroute of #1 and #2 through Alvin is the former Texas Chief route from Santa Fe operations. Why did it take Amtrak so long to find it, or were their further complications?
The soil around the bents was scoured. So no skin friction or bracing on thin columns.
About 5 acres of river bank was scoured 30 ft deep.
Sonar.
Really tricky, if you drive pile you disturb the comromised pier. The actual solution will be very inventive. This should end up being an award winning reconstruction.
The connection between BNSF Galveston Sub and UP Glidden Sub at Rosenberg is limited. Trains can only go from westbound UP Glidden to northbound BNSF Galveston or southbound BNSF to eastbound UP. So the Sunset Limited eastbound on UP Glidden has to cross the former Tower 17 interlocking, stop and wait a few minutes for signals to clear, back up onto BNSF Galveston, stop and wait a few minutes for signals to clear, then cross Tower 17 interlocking southbound on BNSF Galveston and head for Alvin. The westbound Sunset Limited has to pass Tower 17 northbound on BNSF, back onto UP, then proceed west through Tower 17 towards San Antonio. It’s even more fun to watch when 75-100 car UP and KCS unit trains and manifests have to do the same moves.
This is pure speculation but :::
UP has had to spend a lot of funds to access this washout. Access roads on both sides of track, maybe temporary easements, access peermits if government land is involved, maybe waterway restrictions (?), rock for access roads, transportation costs to bring in heavy machinery and temporary materials.
Then UP will have all the cleanup and restoration work for any access roads.
This route has been noted on the Sunset double tracking thread to become 2 MT…
If UP can update their engineering for the bridge replacement either a single track or double track bridge if may be much more economical to at least build new piers and piling bents now. Thaat way UP will not need to bring in equipment when the bridge is double tracked or a whole new bridge built. UP probably cannot get truss or prestressed bridge members built in a timely manner but who knows ? Any idea of what the present bridge’s cooper rating is ? Is it possible that even a repair will reduce its rating ?
Of course a lot will depend if any corp of enginers review is needed. That work to build the piers and bents could save a lot of future funds ?
I have to wonder a small detail further:
If restoring ‘bents’ does the exact structure have to be replaced in detail, or can a somewhat stronger replacement be put in with the same ‘footprint’ in the rivercourse?
Very common in modern precast concrete construction is a bridge structure that is wider, but statically balanced, over central piers. It occurs to me that this bridge could be redesigned with a much reinforced pier to which a cantilever top and then two tracks could be applied ‘entirely above the river’ (and perhaps thereby reducing or even avoiding steps of a permitting process, environmental review, etc.)
An alternative would be to build the ‘replacement’ bridge gantleted, so that only some relatively simple operating restrictions, made particularly reliable with PtC, would be required to coordinate double-track operation across it with only minimum speed or braking restrictions and no points (and simple frogs).
