WARNING! Long-winded explanations and findings ahead!
Well, we may be getting a step closer to understanding the issues with the Bachmann EZ Command DCC System. I received the below cc:’d e-mail from “the dealer” late this afternoon, that was originally addressed to Joe Freeman, VP of Sales, at Bachmann Industries.
The e-mail content is not edited in any way and is exactly what was sent to me – typos and all. My only modifications were to the format (i.e. paragraph breaks), to help make the e-mail a little easier to read:
Joe,
Thank you for your comments.
There is a problem using the Bachmann DCC System to program “other manufacutres decoders”, Digitrax, NCE& TCS. Not quite as I had indicated, sorry for the oversight.
Yes, you can program other manufactures decoders… only in ISOLATION… be carefull,
if you have any more of the"other manufactures decoders" on the track at the same time, and follow your instructions, unlike the Bachmann decoders, they will all be programmed to the same address.
Essentially the customers layout becomes a programming track for “other manufactures decoders” unless removed. This will surely confuse people and may be impractical.
We tested an EZ Command here and confirmed this.
Thanks,
[Dealer]
So, at least according to the dealer, there still are some programming issues with the Bachmann, but not to the same extent, as he originally believed.
The locomotives can be programmed, but…the programming track and/or locomotive has to be “isolated” from the rest of the main track, in order NOT to inadvertently reprogram the “other manufacturer’s decoders” – i.e. Digitrax, NCE, and TCS. (I’m assum
