The small shortline railway that serves my town currently has a 220,000 lb weight limit and I’m curious what all is involved in upgrading the track to 263,000 or 286,000 lbs. Is it just heavier rail and reinforcing or replacing bridges or does it require rebuilding the whole roadbed? There’s no major bridges on the line and I’ve always wondered why they didn’t upgrade it for heavier cars.
Setting bridges aside, the issues will be rail weight and age, ballast type and condition, and tie condition.
My guess is that the customer can live with 220,000# cars and the carrier sees not enough benefit to spend the money. This is particularly true if there is one customer and they are economically insecure.
And a big part of this will be each customer’s ‘last mile’ of siding to their facility for loading.
In some cases, it might be possible for the railroad to construct a bulk unloading facility for multiple clients, like the one for covered hoppers in Erie, PA, which provides truck access (probably on a gravel apron) to a strengthened set-out track which can then be regularly switched. The facility there is not fenced or gated, but any level of cost-effective access security or monitoring could be provided.
(1) What do you consider a major bridge? In a railroader’s world, anything that carries water is considered as a "bridge’ (including drainage pipes and culverts)…All it takes is one small span in a key place to control the rating of an entire line.
(2) You can raise the weight limits for a while. The number of cycles will determine how long that will last. Too many cycles and game over.
(3) Most independent shortlines can’t afford an engineer (bridge, signal or track)…That being said, the mandatory FRA bridge rating and bridge program rules of the last ten years may have forced the “we run trains” operating bubbas to wake up and understand what they have been running on all these years after a consultant was brought in to keep the shortline in FRA compliance.
(4). A switch to welded rail along with an overdue tie program can do wonders. Replacing tired OTM (especially joint bars) and a little surfacing does great things when you add a little cascaded-down secondhand rail (probably heavier than what was there to start with*)…The industry is starting to see issues with where to place some of that secondhand welded rail that is still servicable, but should not be in heavy haul high-tonnage use. (not enough proper sized SH tie plates, etc)
Light weight rail is not worth flashbutt welding, especially if it is end-battered (badly needing to be cropped on the ends) and near the end of its life. (with many shortlines, already beyond that point …JoeK saw that)
…and then there is that customer, the clueless one, that won’t or can’t maintain the track at the industry at the end of the line - even though most of the time that is their responsibilty. Far too many of those to count. (Drives roadmasters and field engineers nuts) … Anyone who reads AAR embargo notices sees that trend (“track conditions”) is only getting worse.
From my experience, it seems that customers, at least the small ones, tend to rely on the Carriers regular MofW personnel to do their track maintenance on a weekend/holiday cash basis. Needless to say these customers are doing everything on the cheap, cheap, cheap.
Larger customers will likely deal with railroad maintenance contractors who will likewise be granted the job on the cheap.
When I was working, I was keeping some statistics on track issues on my division. Some of the main line divisions had rail that was nearing the end of it main line heavy haul life. Once new rail was installed, the incidence of track issues on those territories decreased to almots nil. Rail does wear out - every axle that passes over it adds to the wear, especially when that axle has a loading approaching 40 tons per axle.
Many a foreman/roadmaster/track supervisor has had to deal with the rail customer that is angry about a track caused derailment that was due to failing track structure that has not been maintained (ever)…Gets worse when there is a landlord involved and there is a joint M&O agreement in place that the landlord or industry ignores. (Elkins Act be damned!)
Pig feathers start to fly when there is a “hot” railcar waiting on delivery or a car that needs to be pulled and the track department has spiked the switch o/s because the track is unsafe for any of several reasons (track condition, clearances, water, bad footing, bad vegetation issue, etc.) on the industry’s side of the division of ownership. The shortline version of this can get really strange.
The simple fix for the image above is making rails out of Nitinol.[:-,]
What’s funny is that the two people I’ve learned the most about Nitinol were my oldest son and my cardiologist. FWIW, my oldest son is working on a PhD in ME with focus on materials science.
Most shortlines live on a hand to mouth existance ("shoestring operations with scary financing).
Unless there is some justification to improve track to handle increased tonnage, not gonna happen. 263K operation on existing track, roadbed and structures will do just fine with careful maintenance. Heavier tonnage will speed up the deterioration of the track, bridges, and roadbed …but you can still run on it to a point. Upgrading to 286 or 315K ratings is not cheap.
Somebody hopefully is looking at existing trackage, tonnage and train frequency and the required FRA Bridge Maintenance Plan that is in effect for the line. (and is NOT one of the “we run trains” operating knuckleheads that are so prevelant in shortline management)
Hardly simple. Remember how rails are made, and their heads hardened. What would you have to do to Nitinol rails to establish straight rather than formed alignment… and then do all over again once the rails have been laid in a different alignment in 3 dimensions… and then do all over again when you turn the rail to equalize wear… [D)]
As for forming nitinol rails, it’s a simple matter of heating the rail up to 500ºC and then massaging it into shape, followed by cooling. (N.B. “simple matter” as in " just a simple matter of programming")
I wonder if rail snakes can reach the necessary temperature for the necessary time. It is fun to imagine a rail-bending facility with a gantry a couple of acres in area, which bends the rails to precise top-down geometry depending on where they are to be installed and then anneals or whatever you call it the rails. Of course you then have to bend them straight again for the rail train, and then heat them in situ so they resume the desired curve…
Perhaps a part of Don’s upcoming ‘railroading in 2050’ piece… ???
There is no need for Nitinol. The problem has already been solved by the resiliency of steel rail, plus adequate securement to ties and ballast, and optimum neutral temperature during rail installation. This is well explained in detail in the above linked video posted by Balt.
I realize that Nitinol was just tongue and cheek as a fantasy to solve the problem of expansion and contraction. My point is that the seemingly impossible feat of restraining the rail so it cannot change length sufficiently to buckle or pull apart is not well understood because expansion and contraction of materials is commonly believed to be an irresistible force. The use of Nitinol is one way to illustrate the solution concept. It shows that the common belief that expansion and contraction are unstoppable is true, but the overall object size can nevertheless be restrained as though steel rails were rubber. I think the above video does an exceptionally good job of illustrating this point.
If that were what we were going to make fun of, we’d have used Invar (or Elinvar for overkill). Nitinol is shape memory, allowing you to fix the kinking by heating the rail in the field.
Of course, there are ‘certain other drawbacks’ to using Nitinol alloy in 136lb rail that is supposed to be field-welded…
It’s only ‘seemingly impossible’ because the ‘common belief’ is wrong. Interestingly enough, there is a discussion in Machinery’s Handbook of precisely how the cross-sectional area vs. density of a material changes when it is heated (or cooled) with constraint. Any real track engineer understands all this clearly as it was part of his education.
Well, it shows no such thing, but I think you need to go back and review your material physics. You’re confusing the effect of heating on material structure (which is “unstoppable” in the sense that molecular motion is the actual effect of ‘heating’) with physical expansion (which can be, and is, constrained by approp
