Using common paver sand for ground cover
I have an updated webpage discussing the use of home improvement sand as a replacement for decomposed granite as a simple ground cover.
http://www.pacificcoastairlinerr.com/gravel
Hope that helps someone[:D][:D]
Harold
Thanks for the tip, that’s a lot cheaper than woodland scenics AND you get far more of it!!
I use a grey paver sand (looks almost like kitty litter) as balast. It’s cheap and I can get a ton of it for a fraction of the cost for a woodlandscenics canister.
be careful about the sand you choose…there are some sands out there that contain iron…not a good thing for motor winding internals…picks it up like a magnet from the track and trashes your engines…Chuck
I’ve been buying “brown” colored sand from Hobby Lobby. It works well and actually looks better in photographs than it does in person, but it makes a decent ground cover. Perhaps it’s a little bit “Oklahoma Clay Red”, but I like to look of it. If I can figure out how to post a picture on here I will.
two things to think about if you use pavers sand as dano sand it looks lik kitty litter. Therefore if you have a cat IT IS kitty litter. I learned the hard way. Also if it gets wet it makes a clay like soup that if it gets on your track you will have a whole lot of cleaning. Andrew
Andrew-
Correct you are BUT, if the sand is glued down (with the traditional 50/50 water/elmers mix) then cats hate the stuff cuz it’s like scratching at a rough concrete block, I should know i have 2 cats. At least one of my cats only sleeps on the undeveloped (pink foam) areas. The other ignores the layout completely [:)]
