I am wanting to make a mountain with a tunnel or two using 1/2’’ blue foam board and need some advice. I have seen pics of other mountains here that look simply great and I would like to know how you do it. I am thinking of making a base mountain from the foam and use some rocks I have cast from WS rock molds for some of the clifs, can this be done to look real? Also how do you carve the foam into washes, gullys, and rocks, and what do you use to cover it with, some form of ground goop if I understand correctly.
What is the best to use to glue the foam board together? I know this is a lot to ask but I know it can be done to look great (Art Hill) but not sure I can do it. Please help me in any way you can, a tutorial would be nice if you have one.
I want to get some knowledge before I start so I won’t be totally in the dark, I have got 2 pieces of foam and will be working on the N scale for now but will want to make some for the HO scale when I get to that point. Thanks for the help. Mike
