I am planning on scratchbuilding a factory based on a prototype I like, and have a couple of questions. For context, the prototype was completely painted solid red with no mortar showing.
Also, I was going to build the structure with a frame/subframe out of 0.040" styrene and then cover that all with the brick sheets (because they are probably too thin).
I want to use plastic brick sheets but don’t know a good brand for HO scale. I don’t want paper, or laser-cut wood, or resin. I would like to use plastic. Perferably, the sheets will be at least 6" wide and as long as possible. Can anyone recommend a brand?
Also, does anyone know of a recent MR article that discussed this type of construction? I recall seeing recent articles on building kits made of brick-molded walls, and structures made from plaster walls that have brick detail, but none showing brick-over-styrene.
Finally, one side of the wall will have a prominent billboard type “painting.” Fortunately or unfortunately, the picture I am working from shows the brand new painting so I cannot weather it. I was going to use decals or have it printed on paper and sanded really thin, but I cannot hide any errors or sins with weathering. Any advice?
Thanks.
