Using rail joiners with Peco track
What’s the best way to connect a rail joiner with a Peco turnout?
They do not have the gap in the ties (like Atlas) where I can place a rail joiner. It would seem I need to cut off the ties at the end? If so, what is best tool to use for cutting? A Razorsaw? Once rail joiner is on rail, do I just “slide” the cut-off ties back under the rail and glue them in place somehow? What’s a good way to do this?
Thanks in advance!
peco turnout
  • Use Peco joiners
  • Cut off the tie plate detail that attaches to the foot of the rail. Do not cut off the ties.
I use Atlas code 80 N scale joiners and they slip into the little pockets Peco makes at the end of the ties. The tie with the two heavy spike heads is simply left as is. The initial fit is a bit tight, then the plastic gives way much better the second time.
I don’t cut anything.
Although you need to slice off the spike heads with a #11 Xacto (or a Woodland Scenic foam knife which is pretty nifty for this) there is the nice recess to accept the Peco joiner.
DO NOT CUT OFF THE TIES.
You don’t have to slice off the spike heads if you use a small enough rail joiner.
The music was so soothing that I fell sound asleep early on. When I woke up near the end of the video to discover how easy it was done and how professionally done it appeared, I began to hate the video and the narrator. [(-D]
Cripes, when I get done, it doesn’t look anything as clean as that guy’s installation. I did appreciate his use of track nails on the ties outside of the rails instead of between the rails. That is what I have done on my new layout - - nailed outside of the rails. On my old layout, I nailed in the center of the ties and on subsequent around-the-layout videos, the nail heads appeared like miniature bowling balls. [(-D][(-D]
OK, I was sufficiently intrigued with the video that I decided to try it with Atlas Code 83 flextrack and Atlas Code 83/100 rail joiners.
I must say, it is a time consuming procedure but it does work, and I really like the finished appearance.
My procedure has been to remove two ties on either side of the rail joint, add the two rail joiners, and then slip the ties back under the rail joiner. But, the trouble with that procedure is that you cannot get the ties up snug against the rails.
It is not that visually noticeable as you look down on the layout, but if you video your trains running down the track, those replaced ties are very noticeable, even after ballasting.
My biggest objection to this procedure is the time involved. I have a 162’ double mainline. I think that it might take 5 years to complete the double mainline using this procedure. OK, perhaps I exaggerate the 5-year time span, but it would take considerable time.
One final observation. Using this procedure creates a slight hump under the rail joiner, so you need to be sure to remove that hump, however slight, with nails or caulk at the site of the rail joiners.
Short enough, yes. That weakens the joint though.
The Peco method works for Atlas flex track. The plastic tie strips under Atlas flex track is much stiffer though.
We have made use of Atlas moulded four tie flex track ends. Works great. You remove four ties off each end of the flex track to accept these ends. Some filing of cut rail ends is necessary to facilitate slipping the tie ends onto the bare rails.
Walthers new Shinohara flex track already has the track nail holes outside the gauge. Walthers supplies handy two tie sections of bare ties to slip under the cut ends of joined flex track.
We also tried the Peco method of drilling the track nail holes outside the gauge with very limited success. The one major drawback to Peco track is the flimsy hollow backed tie strips. Track nailing must be done very carefully or the tie gets stripped off the rail. Ironically, this method works better with the more robust Atlas flex track.
On my Peco code 83 curved turnout, I was able to slip the Peco insulated rail joiner on without cutting anything. There is a recess or pocket designed in so you can connect a rail joiner without any cutting.
You do have to use the Peco code 83 insulated rail joiner as the Atlas are too fat. But the code 83 metal joiners should fit just as well as the Peco insulated.
Well you can but it ain’t easy.
Slicing off the spike heads makes it much easier.
There is no need to slice spike heads or any of that sort of thing! There is a pocket carved out under the tie for the Peco joiners to slide in. A very clever design the eliminates the need for those unsightly odd shaped end ties found on Atlas track.
Look at the Peco turnout from the end - you’ll see the space below the rail.
Randy is right No need to slice off spike heads. Not easy? I don’t have special skills and didn’t find it difficult.
The heavy double spikeheads are designed to keep the rails affixed to the ties as you push a properly sized joiner under the rail. It can be a tight fit if there are burrs or nubbies on the end of the joiner (like you can get when you separate them out of the package). Atlas code 83/100 joiners and similar brands of the same size are too big to fit into the pocket without slicing the double spike heads first, maybe even cut off the entire tie.
All Peco code 83 track products have these pockets. Flex track too.
You will need to do what’s shown in the Peco vide when using the flex track, unless you are laying a long line of perfectly straight sections.
The Peco rail joiners are significantly smaller than Atlas, yet are formed differently and seem to hold tighter even after being pulled apart and put together a few times. The Peco metal ones also come individual, not on metal frets to cut apart. Peco insulated joiners are also small and very unobtrusive - you’d be hard pressed to find them after painting the rails. Those do come on a palstic sprue so you need to trim them carefully to eliminate flash which will prevent them from fitting in the under-tie pocket.
I guarantee you will experience completely unnecessary frustration trying to fit joiners to Peco turnouts unless you first trim off the spike heads from the last rail chair.
The suggestion that doing so weakens the turnout in any way is frankly ridiculous.
Not sure why this minor issue of cutting the webbing is being elevated into a big deal. Cut the webbing if a person wants, if it makes them more comfortable.
Granted I’ve only experimented with a couple, but I’ve linked multiple turnouts together and I currently have one turnout and 3 sectiosn of flex set up on my bench as a little test track. For none of these have I had any problem putting the joiners on the turnout. That’s a couple of #8s, a couple #5s, a #6 (all Electrofrog) and a #6 Unifrog I just got. Maybe I’ll change my tune if I get a dud, but so far so good.
Ridiculous? Hardly. Of course, trimming off spike heads at the end of the rails weakens the turnout. How much? Who’s to say. Maybe trimming off a spike head in the middle of a turnout may not weaken the turnout, but surely it weakens the turnout at the end of the rails.
Are you using Peco joiners sold for code 83 track? So far my experience with inserting Peco branded joiners without trimming or cutting spike heads at the ends of turnouts has been anything but frustration.
I watched the Peco video - it’s a great presentation for anyone who hasn’t laid flex track before.
