Recently looking at some photos of the nifty little USRA US Army 0-6-0’s I noticed the sand domes on them to be different. Seems the Lima versions had one single, larger sand dome while the ALco versions had 2 smaller round ones. Is/was there any particular reason for this deviation in an otherwise identical locomotive?
Also many of both manufacturers seem to place the CC airpump on the left side of the boiler and others on the front pilot deck.
I don’t seem to be able to find much on these engines other than specs and photos.
I guess you’re thinking of the S-160s. ROCO is the only one that has made one in HO RTR and they run extremely well. They have a tender drive system that’s unusal by American standards but I understand this is common in Europe for their model steamers. The craftsman kit version by Model Loco also runs very smoothly. Both are expensive though.
As to the pumps being moved for clearance I don’t buy that as there’s ample side clearance on them and most engines, even considering the tighter European loading gauge, don’t have that problem. I inderstand the front pump locations had more to do with weight distribution and sometimes they could cause cracking of the boiler shells.
My buddyand I both bought ROCOs when they were first brought out and they are smooth and nice. I’m not a fan of their sound system and will probably replace it. My friend pulled his out and installed a T2 and he’s much happier with that.
I was told by an old Western Maryland Ry engineer they moved the side pumps to the front of the smokebox and were told by management it was to relieve stresses on the boiler shell. He said the Union told him it was to transfer weight to the front end off the drivers. Doesn’t make sense to me to do that as they were used on the Thomas Subdivision and needed all the TE they could get to climb the Black Fork Grade. We’ll probably never know.
I saw them at Ft. Eustis a bit later. My first one was on the Reader RR with 1702. My wife and I spent most Saturdays in 1972-73 driving her with Mr. McBride and Jarrel the fireman. Great times. I have been following the S-160’s and the Ma&Pa too for about 53 years. The Ma&Pa tested the 2628 (Ft. Eustis 611) when they converted her to the Franklin Rotary Poppet VG. She’s alive after a horrible life since the Army. In Cumberland, MD and the owner hopes to make her run someday. I’m hopeful but very doubtful.
I purchased 4 of the Model Loco kits (DJH) many years ago and have one built so far. The others are not needed so will remain in their boxes. These kits are very easy to build in spite of their very many parts. The steam kits from the UK have all American steam kits beat so bad it’s like comparing Tyco to brass imports. The kits assemble easy with very minimal hand tools and things actually fit!
My friend models the Ma&Pa so he actually did the conversion of the 2628 with the Franklin gear. It’s pretty remarkble!
Designed by col. Howard G hill, the S160 were designed to be fat boilered engines. Not intended for Europe but US base service. A war stop gap so diesel production could be freed up during war production. Big boilered for more steam capacity. They also have the unigue feature that the S100 and S160 were designed to have lead and trailing trucks added. for 2-6-0, 2-6-2 or oddly 0-6-2. The “s” was a classifiction by alco to denote thousands. The compressor is on the front for centerline weight distribution and stability. That fat boiler made them a little top heavy on the S160. The sand domes, was a builders prefference. both configureations had the same total sand capacity. At least 8 of these wee beasties still exist. #9 of new hope and ivy land now down at sms in southern NJ
If they were designed for US base service, they would have been designed with typical US clearances.
A GN F-8 2-8-0 is a pretty typical sized 2-8-0. Overall height was 15’-4". Very typical. But the S160 was only 12’-10 1/2" tall–Two and a half feet shorter. For what?
Neither was the S160 “big boilered” by American standards. The F-8 had a boiler diameter of 74"–the “big boilered” S160 had a boiler diameter of about 71 1/2". Smaller. Not bigger.
No. These locomotives were designed for European clearances.
I have read (don’t ask me where), that many of the US Army steam locomotives were built to operate, if needed, in foreign war zones. It was explained that this was the reason for some strange detail differences on US Army locomotives even those built to a “standard” design.
I have even heard that some could easily be “reguaged” if necessary.
There are a few books out about the S-160 2-8-0s. They were built for use in the European Theatre so they were rather small engines and built to ensure they had clearance for any country in Europe they might be operated by. There were 2,200 of them made by Alco, Lima and Baldwin. They were not multi-gauge engines and were standard gauge. The multi-gauge engines mentioned were, I believe, some narrow gauge 2-8-2’s similar to the Tweetsie or Dollywood engines.
The S-160 was definitely not a big boilered or even a big engine by any means. They were quite small and not top heavy. According to the books and information I have they were very efficient, ran well and gave good service in Europe and in the USA. The Brits had trouble with the water gauges as they weren’t familiar with them which caused a few to blow up. Only a handful of them remained in the States and many are on the bottom of the Atlantic thanks to Hitler’s U-Boat fleet.
Fortunately for those of us who are infatuated by the S-160s there are several in the UK that operate and soon to be a couple more in the US operating. Alaska RR 557 is nearing completion and the folks in Ohio are supposed to be getting the 612 operational. The Smokey Mountain (ex-Reader RR) 1702 has been running there for years. Not sure if it’s out for maintenance or not at this time. The remaining Ft. Eustis engines are around but in various states of disrepair.
To the best of my reading and searching the S-160s they were never designed to be anything BUT 2-8-0s. Maybe you mean the USRA 0-6-0s? The Colorado Midland owned several and converted them to 2-6-0s. When sold to N&PBL they were converted back to 0-6-0 configuration. Not sure if that was before the sale or after. I don’t think they were DESIGNED to be converted into 2-6-0 or 2-6-2 configurations. They were designed by the USRA as a light switcher. But who knows what went through a shop foreman’s mind?
Class 155 - Eighty saturated USRA 0-6-0’s for use domestically. Reason for one vs two domes is just a matter of of what the builder liked and had no operational reasons (Lima liked combining domes). The reason for the pilot deck mounted air compressor is the same as the reason that many modern locos had two of them mounted on the pilot deck on either side of the smoke box, to provide desirable front end weight. Here’s a Lima built KCS 2-10-4 with both these features
I don’t know if it matters if the weight distribution is uneven. But considering that 0-X-0’s were bi-directional, I’m not sure what the point would be to do it intentionally.
My impression was that BEAUSABRE was asserting that by moving the compressor to the front, it would allow for an even distribution of weight on the axles of the Army 0-6-0’s. I pointed out that this goal was accomplished without doing so, on the GN locomotives.
Pulling power is proportional to overall weight on drivers (leaving out booster engines, etc). For a locomotive with only drivers, repositioning weighty elements should have no effect on pulling ability–the overall weight on drivers remains the same.
Some people may believe that having an equal weight on all drivers make the locomotive pull more (or perhaps less) than an unequal weight distribution. This may have been tested in the real world, and I would be very happy to read an article describing this event.
One good reason to have equal weight distribution is that higher axle loading produces greater stress on track. Even if it’s only one axle. So there IS an incentive to have an equal weight on the axles.
Another is that wear will be increased for the bearings related to the heavy axle. THAT might be non-linear, in a bad way.
Adding lead and trailing trucks complicates things a bit, but we were only talking switchers.
Linn Westcott in Kalmbach’s Model Railroader Cyclopedia Vol. 1 Steam Locomotives, says the reason the air pumps/compressors were moved to the front of the smokebox (or mounted on the pilot) was to provide better balance: those things were heavy.
Perhaps the S-155 0-6-0’s were designed unbalanced, and moving the compressor corrected that. Or perhaps they WERE designed balanced, and someone wanted to change that.
What the move will NOT do is change the weight on the drivers. And, subject to my earlier comments, it’s the weight on the drivers that determines the amount of tractive effort possible. And that is a key element of a switching locomotive.
