I have before me samples of 3/16" thick Vinylbed roadbed and Woodland Scenics (WS) roadbed. I am trying to determine which one to use for my new layout. The width of Vinylbed’s product strikes me as being strange. It is 3/16" to 1/4" narrower than WS’s and Midwest’s products.
Is Vinylbed’s roadbed the one that has the unrealistical width? I prefer it otherwise although it does cost two-thirds more than WS’s product.
I would much appreciate any guidance that anyone can give me on this.
I can’t speak for the vinylbed as I’ve never used it, but I used cork in the past and now I’m using the Woodland Scnics and I love it. I would never go back to cork.
I ue the HO size for my main tracks (HO scale), and the N scale roadbed under my sidings to lower them a little. The effect looks good on what I’ve built so far.
I recently used Vinylbed to build a layout and discovered a few things about it.
Overall, I liked how it turned out, but I found out that since it is made to order, it varies in texture from batch to batch. It can range from pretty firm to very spongy. The stuff I got was about in the middle, which wasn’t too bad.
If you get spongy material, it’s more difficult to cut even using using a very sharp knife or razor blade.
The most frustrating feature is that every piece is made to order and they don’t stock a single piece of roadbed (or so they say). That means you have to wait 3-6 weeks to get anything and you have to make sure you order enough in advance. Otherwise, you have to wait another 3-6 weeks to get any more. Also, you can only order it by the case, which isn’t to bad to start, but it’s a pain if you only need a few pieces.
I still think it’s neat stuff. Just make sure you’re aware of the ordering policies.
I e-mailed the following to manufacturer of Vinylbed:
Your 3/16" HO roadbed is comparable in thickness to Woodland Scenics’ and Midwest’s roadbed. Yet, its width is 3/16" to 1/4" narrower than then others. Why is that? I would suppose that you folks would argue that your product’s width is the one that is more realistic. Would you please comment on this question of roadbed width?
They quickly wrote back responding in part with this:
Back in 1988, before we began our roadbed business we did a lot of research at the NMRA library in Chattanooga Tennessee. Our dimensions are a scale design taken from roadbed standards of real life-size trains. The information is located at the library in the ‘Railway & Engineering Encyclopedia’.
Okay, all of you prototype and NMRA standards experts, would you please fact check this? Both roadbeds that I referenced above have the same thinkness. Yet, WS’s is 3/16" to 1/4" wider. Both cannot be most like the prototype.
