I have just installed the newly released 130 ft turntable. It moves smoothly and looks good. I have two questions: 1) In programming, the instructions ask you to press the “set” button as you maneuver the bridge into each desired location. I press “set” and then the arrow requested and nothing happens. If I move the bridge to a stop I want to set, then press “set”, it places the position into memory but when I move to my stops in normal operation, they are off mark a bit. 2) If a loco enters the turntable facing forward on a service track, and I need to turn the table to meet a radial track, with the loco facing the same direction, the “position” light flashes when I set the position, indicating I am too close to a previously selected stop. My roundhouse is directly across from the service tracks with the “no tracks” portion of the pit at right angles as specified. Does this mean I cannot program the radial tracks and if so, why not? I Am I missing something??
John
