The Advanced Control Module (ACM) manual is missing details of how to use relays to power the aligned roundhouse tracks as the turntable moves to a track position. The link is to a PDF that is an attempt to fill in some blanks. Feel free to let me know of issues you might find and I will update the document.
If you already have the ACM for DCC operation of the turntable, then the relays are less than $10. Again, it depends on your goals for operating the turntable and layout. For me mine are total control though JMRI without a physical control panel.
I’m not an expert on Walthers ACM but the PDF looks like they covered pretty much everything. If you have more than 4 tracks you can get a 8 relay module off eBay.
I’m not apposed to using relay control but I’m not into using my computer to run my trains, it seems to me that it would take the fun out of model railroading.
I automated my turntable indexing with IR sensors and a rotary switch but manually controlled the five finger way.
I’ve seen many post on the forum about problems with the Wathers ACM that would have created a negative influence on me without adding more possible problems with the above JMRI control.
I am the author of the PDF. I offer it only as an aid to anyone using the ACM to control a Walthers turntable and having problems with: DCC for the ACM, power to roundhouse tracks, or JMRI. When I started the project I found I was as lost as many people that have posted about the ACM in the past. I wish I had had this. Regarding JMRI, the support for the ACM is not there and I provide 2 different JMRI scripts to control the ACM.
