I know the Mainline F7 has not been released yet, so it is somewhat hypothetical to ask, but judging other Mainline product, and with some extrapolation of the older Proto 1000 F-unit, which F7 would you vote for in terms of detail and finish? : Wlthers Mainline or Bachmann?
I dropped accuracy because both are supposed to be non-prototypical). I also dropped the running quality because both are (AFAIK) run fairly good.
Not sure “non-prototypical” is exactly correct. Yes they are lower-priced models that are kind of “one size fits all” in that they don’t necessarily have railroad- or road-number-specific detailing. But as far as overall dimensions and such I think both are good.
I’d probably go with Walthers Mainline, primarily because their F-7 engines come with the side handrails installed. With the Bachmann units, you’d have to drill holes and add the handrails yourself (most likely using Walthers “diesel dress-up kit”).
It sounds like you are most concerned with the quality of the paint job. In that case I would say Walthers. It seems like every time they come out with a new model it looks better than previous ones.
I really admire the way Walthers is constantly improving.
I would honestly go with the Mainline units, as I have both brands. I feel that the Walthers units have closer paint to the prototype than bachmann. If you wish to buy with or eventually add DCC, again I side with walthers as the decoders with sound have a crisper sound than the bachmann decoders. If you go with DCC Only, do not buy bachmann as their standard decoders without sound put off a very loud hum. If I would have known about the Walthers Mainline units at the time I bought some of my Bachmanns, I would have taken Mainline as (usually) they are less expensive and are more RTR in some cases. This a kind of case where you are comparing a higher end model (Walthers) to a starter model (Bachmann). It’s not that I have anything against Bachman, but if I were you, I would go with Walthers Mainline.
Although the Bachmam Spectrum line of diesels are much better with thier newer products, the Walther’s is still a better chassis in motor drive and trucks. I would also suggest that the paint and detail is also superior. I have newer Bachman steam (B&O EM1 my latest) and am rather impressed with the overall detail and running properties. Still not convinced about the diesel line though.
I have a number of Bachmann DCC equipped and with sound. All run well, a couple a little noisy, but the value of the engine is fine for me. If a rivet counter says something to me, I show them the door and tell them not to let it hit them on the way out [;)]
Glad it was a rather simple repair. I had 4 Bachman Spectrum GP30s. Bought one pair at first, they ran horribly right out of the box. After some break in, one started to run somewhat decent, the other one died. Brought it back and switched out the next one was worse, I wanted that B&O sunburst and one Capital Dome to run as a pair. Never did get a pair to actually run together properly. Brought them all back and ended up with my 1st F units. The Stewart/ Kato F3 phase 4 ABBAs are still running flawlesslt today 15 years later. I shyed away from spectrum and any Bachman diesel for quite a while. The Spectrum steam are quite decent and have noticed that the line of the GP units of the past few years are quite good runners. About time.
