Hi folks,
Almost done with my HO slag pot gantry crane build. In need of rough measurements of Walthers overhead crane cab .
Could be either kit. The heavy duty overhead crane or the smaller overhead crane.
Millimeter preferably ,at this point inches would be great too. Ready to be done with this build.
Thank you for your time.
Hello,
The larger crane, moulded in yellow, the cab measures 20.65 mm wide by 21.05mm deep by 28mm overall height from bottom of floor to top of roof.
The “smaller” one moulded in gray is 21.5mm wide by 21.6 mm deep by 27 mm high over bottom of floor to top of roof.
Both cabs have a platform in front of the door that is 8.5 mm deep by the same width as the cab.
Hope that helps, Ed
