Hope all your MRRding dreams come true, here’s a question, I have a track plan that I like very much, it’s a HO plan 22 x 20, but I measured it to Nscale [which I’am working in] 11 x 10, my room size is 10 x 20, I might have asked this question before, but is it possible to turn this plan to a 2 level plan,?? I have two peninsulas in the middle, and two staging yards at each end, with reversal loops,I wish I could download a picture of this plan, but I always have trouble doing so,
once again, Have a very Merry Christmas & and a SAFE N HAPPY RAILING[8D] NEW YEAR!!!
First thhing to remember is that a plan does not reduce exactly 1/2 when changing scales. Your aisles still need to be sized for the same operators.
It is difficult to know how easy it is to make it a double deck plan without seeing it. Hopefully someone can give you understandable instructions on how to download a picture of your plan. (That ain’t me.)
Restating the question: can I take a plan and make it different. I suppose so but the layout congniceti won’t have much to say unless they can see it. What is the plan and where did you see it? What I lack in electrical skill, I make up for in computer skills.
The conversion factor from HO to N is .54375 so it is a little bigger than you think.
And that conversion factor doesn’t factor in the aisle either as pointed out above. A 22x20 plan does not scale to even 12x11 because humans dont scale down.
At that time it was pointed out to you that an N scale layout is not half the size of the equivalent HO layout, but a little larger. (About 54.4%, from 87.1/160)
And because humans don’t scale down with their model trains, you might have to allow for even more width to accommodate aisles.
So a 22X20 HO plan scales to at least 10’ 10½" X 11’ 10½" – and after allowing for wider aisles, it may not fit your room as originally drawn – but could possibly be reworked for your relatively longer room.
Most layout concepts can be reworked for multiple scenicked decks, but your plan would be starting from scratch and you’ll need a lot of running length for the climb.
Plus, you didn’t indicate what layout you’re taking about now, so there’s no way for anyone to know what the possibilities might be.
If you provide more information, folks may be able to help you.
I’m not familiar with any of them, so am not qualified to recommend a particular one.
I’ve used photobucket, which is a paid site, for over 15 years, although only the last few years have required payment, which is quite reasonable, in my opinion.
Once you’ve chosen and joined a site, find their instructions for adding photos to your account, and also instructions for posting them here.
In my photobucket account, I simply choose the “album” from which I want the photo, then click on that photo’s thumbnail image, which yields an enlarged view, with a bunch of lines of data beside it.
I simply click on the line which begins with “img…” and that line of data is copied. I then come here to my reply, and “paste” that data in the place where I want the picture to appear. It will show as a line of data, but will appear as a picture when you either “Preview” or “Post” your offering.
track length around a 10x20 room is at most ~60ft, requiring a 2.5% grade to reach 18" with no flat areas for sidings or spurs where cars could be spotted w/o rolling.
An 11x20 space is big enough that even with HO you could combine some grade around the room, but have some flat areas, along with a smaller (fewer turns) helix in one corner to get the elevation required. For N scale, a helix of 24" radius would need 6 turns at about a 2.1% grade to get 18" separation. But if just half of the 60’ around the room were on a s.5% grade, you would only need 3 turns of the helix to make up the difference. and 24" radius is a pretty wide curve for N scale.
11x20 is a pretty decent area, the only real issue is that the 11’ width does not allow a peninsula with a turnback curve, with decent aisles. You might squeeze it in with a tight pinch point at the end of the peninsula, but you would probably come to regret that. It IS wide enough to do a yard on a peninsula, or a switching area, or industrial branch.
Yes, but losing the train in the helix for 3 turns and 9 inches is better than losing it for 6 turns and 18 inches. Half the hidden running.
I was considering that, but I don;t have much area on my lower level to have grads on because of the main yard being there. Plus if anything, it makes more sense for the upper level, which represents more hilly areas, to climb, so once it gets to the top of my helix, the upper level may climb somewhat around the room until it gets to staging. I’ll certainly have plenty of clerance between staging yards, and enough space in the middle that I could use the mole concept to swap equipment and extend the number of trains without eating up the entire laundry area with more staging tracks.
Depends on how large you are. As a short pinch point, 30" is ok for me, otherwise I wouldn;t be able to get throught he doors of my house. But to stand there and operate trains, I consider 36" a bare minimum, and my plan uses 48" aisles.
For N scale, 12" is not bad, and a peninsula could extend almost down to the other end. Linear running, that’s over 90 feet now, in the same 11x20 room. That’s over 2 1/2 scale miles. With one level.
I have to agree with Randy. Having built a double deck layout, and having operated on several others, 30" aisles are simply unacceptable.
Actually, in my opinion, a 30" aisle is not acceptable for any layout, except maybe as a minor “pinch point” as Randy suggests, but not as a running aisle width.
Also like Randy, my new single deck layout will have 48" minimum aisles except one 36" wide, 12" long, pinch point, and will have several open areas much wider
I even shifted the wall for the basement half bath by one stud cavity (16:) so I wouldn;t have anything less than 48" everywhere. No big deal, just menas I have to use the smallest vanity I can find, with a small sink. But there’s the laundry tub for working with plaster and washing paintbrushes, the bathroom sink is just for washing your hands.
