Washers to used for coupler height adjustment
There are metal, fibre, and a whole slew of various plastic washers available out there, which material is best to use between the truck and car body?
As always, thanks.
A few times I used the Kadee fiber.
Brent,
I use metal as rarely as possible.
I found #2 fender washers made out of nylon in 0.010", 0.020", and 0.040" thicknesses in an electronic supply store a couple of years ago. I bought a lifetime supply, and I love them.
-Kevin
I recommend metal washers. They’re more reliable and durable than other materials. You don’t want a washer to break due to unintentional, albeit unlikely, over tightening.
I’ve never used any metal washers ever, only Kadee fiber washers like for the past 30+ years. Never seen any “wear out”.
There are two sizes:
Kadee #208 red - 0.015" thick
Kadee #209 gray - 0.010: thick
I always try to have an envelope of each on hand.
As with me.
Mike.
The Kadee fibre washers are very sturdy and durable .
Only once or twice did I face a car so excessively low that I needed a thicker washer than the Kadees and what I found was the trucks seemed more prone to wobble on a metal washer even though it was smooth and flat.
However note that I said “a car so excessively low” – not a coupler box or coupler that is too low, but the car. If the car is at the correct height I much prefer using an offset shaft Kadee coupler and I keep a supply of both offset options ready at hand.
Dave Nelson
I don’t like to use any more than a single fiber washer. It seems if I use more than one, the car is more likely to rock or wobble and be less stable. So like you, if the car is low enough that one of the thicker washers doesn’t do the job, then look at one of the offset shank couplers to get you to match the height gauge.
For a “car of interest”, I check both the coupler height and the car height.
I prefer to get the car height correct, first. Sources for that information are Official Railway Equipment Registers and also railroad diagram books. I usually install a three-point suspension, which involves washers “under” one truck, and bolster truck bearings for the other.
I then adjust coupler height by raising or lowering the coupler box. Kadee makes shims for lowering coupler boxes:
https://kadee.com/htmbord/page211.htm
If the box has to be raised, I usually remove material from the floor to do it. Or I sometimes leave out the “upper” part of the box and thin the lower. This raises the coupler by about .020".
Ed
I just did an experiment with a piece of 1/4" thick brass, a steel 4-40 screw, and a Kadee red (0.015") washer.
It took a tremedous amount of force. but the screw stripped first, and there was no damage to the washer. I checked the washer thickness, and it still measured 0.015" with my digital micrometer. No visible or measurable deformation.
Then, just for fun, i put the washer in the arbor press, and I put all my weight on it. The washer did deform a little, and was reduced to 0.012" thickness, but that was over 1 ton of pressure.
I do not think there is any cause for concern due to over-tightening.
-Kevin
I use #6 flat washers from the hardware store. Cheap, widely available and they do the job. One flat washer under each truck will bring my couplers up to match my coupler gauge.
I prefer Kadee fiber washers and keep two packs of the red and gray in my washer storage bottles or better known as former pill bottles.
The biggest offenders are resin kits by Westerfield and Funaro & Camerlengo.
In all fairness, I do not use the coupler boxes that come with these kits. Instead I drill and tap the floor 2-56 to take the Kadee coupler boxes. This shop-work might be what makes thicker, or multiple, washers necessary.
EDIT: I just noticed the OP specifcally asked about in between the truck and carbody. The examples above are in bewteen the car floor and coupler box.
-Kevin
the best is what ever you like. i like cheep so i use .010 , .015 made out of evergreen black plastic
Yes, but adjusting coupler height is intimately related to adjusting body height on trucks.
Ed
I’ve done that before, cutting my own, when I was laid off and between jobs; but these days I can afford a couple if dollars for a pack of Kadee fiber washers. It takes time to make your own and hobby time is hard to find for the past year or so.
Thanks for all the responses, everyone.
I went to an industrial electronics store that I often frequent and found Delrin washers. All the small sizes were sold out but I think they would have been ideal. The Delrin seemed to be the same kind of plastic the car and truck were made out of, though I could be wrong. I think the friction between the washer and car/truck would have been minimal as all the surfaces were so smooth.
As far as the fiber washers go, what kind of material is the fiber they are made of? Also what kind of plastic are our rail cars made out of?
I have put in an order for Kadee washers along with a coupler gauge. Mail order is much cheaper than driving into civilization.
i’m retired so time is not important to me , but the nearst hobby shop being a 3 hour drive is , thats why i make my own.
I use the Kadee fiber washers, and I’m not afraid to put two in if necessary. The only problem that I have encountered with the Kadee washers is that sometimes they won’t fit over the bolster post on used Athearn cars. It seems that the previous owners had over tightened the truck screws which caused the bolster posts to flare out. All I do is use a side cutter to cut through the washers on one side and they will slip over the posts quite easily. I have never had to use the Kadee offset couplers and I have done about 200 freight cars. I will admit that there are a few cars where the offset couplers would have been a cleaner solution but if the cars track properly who cares.
In addition to getting the coupler height correct, I think that getting the truck screws adjusted to the right tension is critical. I have always followed the advise that says that one truck should pivot and rock freely (within reason) and the other truck should pivot freely but not rock. That works but it does take a few attempts sometimes to get the screws set properly. Several times I have had the non rocking truck screws set just a bit too tight with the result that they will derail at the slightest opportunity.
Dave
Being retired, then it makes more sense. Although if you get tired of making them, they are only a couple of bucks for a pack, which you can add to an order that comes to your door, if you still buy stuff online or mail order. That said, I expect when I’m retired, my disposable income limited so the equation I have right now, and others here (more money and little time) will be reversed.
