In Sept03 CTT, page 41 is an ad from Williams. A warning is given that Williams locomotives should be run with a tranformer that is at least 90 watts.
I happen to use a Z-750; and have been running trains on about 50 feet of reverse-looped track on my carpet (while my current layout is under construction). I have double-headed locomotives and have never experienced any overheating or deliterious effects from lack of wattage. As a matter of fact, the Williams locos draw less juice than my MTH PS-2s. I’m a bit puzzled by the warning in the Williams ad.
Incidentally, I will continue using the Z-750 (and a second one) that I got in 2 starter sets. As long as things don’t heat up. When they do, that’s when I’ll look into a Z-4000.
Do you think that for some of our medium-sized layouts, there is a wattage overkill? I know the dictim that you can never have enough watts. However, watts is money.
dave vergun
