Hello All,
“Water Dispersment Formula Number 40” (WD-40) was never intended as a lubricant.
As said before it is a form of penetrant and was designed to dry out the contact points in wet ignition systems.
What are you cleaning?
What are you lubricating?
For cleaning my go-to has been 91% isopropyl alcohol. Unfortunately, it has become more difficult to find due to current health concerns.
You can substitute 70% isopropyl alcohol. It works too but might take several passes or soakings, and has also been difficult to find in these times.
Denatured alcohol is another degreaser I use.
If I need an aerosol cleaner I too use CRC “QD Electronic Cleaner”. This is great for flushing out contaminants and is plastic safe.
For track cleaning I have in my arsenal Aero-Car Hobby Lubricant’s “ACT-6006 Track & Rail Cleaner” along with dapol brand “Track Cleaning Fluid” for use in my dapol brand track cleaning car.
Once the items are clean, depending on the component(s), I use White Lithium grease (available at hardware, big-box and auto parts stores) for gears.
Good old “3-In-One” is on hand for light lubrication applications, applied sparingly.
Recently, a technician at Bachmann suggested their proprietary “E-Z Lube”.
This is a plastic compatible, “conductive contact lube”. I was advised to periodically, sparingly, apply to the contact/wiper sides of the wheels on locomotives to promote electrical pickup.
Labelle manufacturers specialty lubricants for hobby applications from greases to oils. I have not had a chance to use their products but they do come highly recommended.
For dry lubrication applications; coupler boxes, I use Graphite Powder.
This can be bought from hobby manufacturers under
