Gidday All, Its that time again, current project is still at an unphotogenic stage, though my turnouts arived in the mail today [:D], so here’s a photo from a few months ago.
Here’s an old Santa Fe SD26 in its ‘as purchased’ state, apart from the scribbled ‘ST’ under the cab window, and the hastily painted blue lines, hauling freight for its new owner Guilfrod Rail
Turnouts in the mail? I think I know what you’ll be up to[:-^]…[dinner]
Mike,
You definetely keep the bar set high around here[:D]
A busy week in a lot of ways, even got some stuff done on the layout.
Installed some hand brakes to aid in switching at several locations and to help cut in helpers at Dove Creek for the long grade up to Durango.
Here’s a pic of a train having the swing helper cut in mid-train, now possible to do without the back half rolling away downgrade[;)]
I equipped another switcher, a first-run Walthers H10-44, with dual gauge couplers. My 44-tonner bangs the narrowgauge cars around fine, but gets winded on more than a coupler of standard gauge ones. #123 is good and heavy and works admirably.[8D]
And did some people-watching while out along the tracks…
Bear, Mike and Mike; you guys definately set the bar high around here.
Managed to finish some cars this past week!
Atlas PS 2003CF Covered Hopper Kit, painted with Floquil C&NW Green and lettered with Herald King Decals.
This is an Accurail 40’ Plug Door Box, that I had originally intended to replace the existing underframe with the Accurail Fishbelly Underframe, but it was 1-1/2 Scale Feet Narrower, I managed to get the Fishbelly Part off the Underframe as the glue had not set up yet, and using my Dremel Tool cut a slot on each side of the the Plug Door Box Underframe to accept the fishbelly sides. I also removed the cast on grabs sill steps and replaced them with wire grabs and A-Line Sill Steps. Painted the car using Scalecoat II Reefer Orange & Black and lettered with decals from Tom’s Hobby Shop. Car was rebuilt by North American in 1954 and leased to the CNJ for use in shipping Ballantine Beer from Newark, NJ to distributors across the country.
IMWX 1937 AAR Box Car Kit, painted with C&NW Green and lettered with Champ Decals.
The tannery is all done except for the landscaping. I still need to add some ground foam and static grass around the concrete apron, but the Gypsolite texture is down, and the turf is glued and dry and ready for the next step.
One more layer of Envirotex should do it for this pond, too.
A modified Dash 9 and an ex-Amtrak “cabbage”, equiped with a generator, for HEP, lead the GLC business train, consisting of restored GN “Big Sky Blue” cafe/lounge, and observation car.
Finaly, a couple of my too many projects are nearing completion. These were completed this week, they are a couple of ranch style houses from previous layouts that I did some restoration work on. Both will go in the village area of Greenvale, the section of my layout I am working on now.
The first is the Atlas ranch house that I built for my first or second layout back in the early 1960s. I was able to remove the roof (good old tube glue) and some other parts, spray the whole thing with primer and finish coat, then brush paint datails and replace the windows with a better material.
The second is a Faller ranch house that my son built for a layout that we worked on in the early 1980s. It was molded in a strange yellow color with a burnt orange color garage and a blue roof
They are not the best models, but do have some sentimental value to me.
There are some awesome scenery scenes today. Work continues on my extension project. Hopefully next week I will start putting up plaster cloth. I also plan on building a large hill off the layout to be placed on the layout in the first photo.
Its been two weeks since I’ve posted on WPF, and in that time I finished the NYC combine. Haven’t been able to work on the layout because of mid-terms.
Bear … Thanks for starting WPF. Looks like another Mike convention. I like the NYC F-units.
Mike (Down Under). The SD26 and the bridge scene look great.
Mike (Middleman) … I like the depot. Not sure what you mean about the hat.
Mike L. …Your layout is inspirational.
Rick … Nice freight cars. I recall the old M&StL.
Mr. B … Tannery is looking fantastic.
DJ (Grampy) … Is Roaring Creek named after locomotive thndering over it? Nice photo!
Mike mbinsewi … Nice layout and business train.
Terry (Texas) … Your yard scene looks outstanding.
George … The house reminds me of neighborhoods when I grew up.
Terry (Wisconsin) … Your “water” looks real. nice scene.
Curt … Good start with the scenery. It will be impressive.
Alex… Nice NYC train.
NP01 … Your panel looks professionally made.
Gary BN24 … Good seeing you. I like your group of locomotives.
Here is my GE 44T… Installing the DCC in this engine was enough to drive me crazy. I would never convert one of these to DCC again… It’s on the branch line.
Thanks! If my photography was as consistently good as yours, it would probably be even more inspirational.[:D]
Was this the original two-motor version? The new single motor version comes with DCC installed (pitch it and use a decent decoder) and performs much better, as well as being very easy to set-up provided you have a small decoder.
The shells interchange, so that part’s easy. I did this when updating my 44-tonner before I installed dual gauge couplers.
I just finished this DPM building for the Club. This will probably be my last DPM kit, at age 75 I don’t have the patience to cope again with the fitting, sanding and tweaking these kits demand.
