Weight of Knuckle Coupler and EOTD
Can someone tell me the approximate weight of a typical knuckle coupler and an EOTD?
The Knuckle weighs about 80 Lbs
The EOT weighs about 40 lbs depending on the type
Depending on the size and type of coupler ,Couplers weigh Roughly 400 lbs to 700 lbs
I would say most of the knuckles I’ve pick up before are in the 70-80 lbs range. 40 lbs sounds about right for a EOT. A knuckle you no from the start is going to be heavy to handle, EOTs are east to pick up just very arkward to handle and store.
