While in the throes of working on a project, I often do some “armchair railroading” on other projects, even going so far as to collect parts and materials for them. The other night I was thinking again of my O scale Thomas (1940’s-'50s-early ‘60s) Consol project only about 2/3 complete due to resolving to finish earlier half-done projects first. For some unknown reason, the real roads usually painted steam loco cab interiors a shade of light green! I seem to recall the late Mel Thornburgh mentioning that he did the same on his O scale models and (as far as I can remember!) every steam loco cab I’ve ever been in was also a pale green of some sort. Has anyone ever noticed and maybe researched a little to see what color of model paint might match? I’m a comolete mutt when it comes to color matching. Thanks–and happy railroadin’!
For most steam-era railroads, seems like the default interior paint for anything - cabooses, roundhouses, passenger cars, engine cabs, etc. was ‘light industrial green’. I think Tamiya’s “Cockpit Green” seems about right. Same color was often used in airplanes, airplane hangars and such.
I have a copy of a Pennsylvania Railroad 10/8/1929 Painting instruction for Locomotives and Tenders booklet. In it is mentioned a color the PRR calls Interior Cab Green, later described as “Medium Green”.
This panoramic view of the cab interior of a PRR H6 No. 2846 will confirm what I recall seeing in several other steam locomotive cabs:
I’ve seen some diesel cabs painted in this shade of green as well.
Other diesels used a “suede gray” or a variation of “Sea Foam Green” I have used some older Floquil “Reading Green” for cab interiors. B-N green might be a good stand-in.
Here’s CNR’s Mountain 6060, when it was used in place of one of the usual RDC trains between Toronto and Niagara Falls, Ontario, on Wednesdays and Saturdays in the mid-'70s…
The pale green is visible inside the cab door, where the jump-seat for the head-end brakeman is located.
I mixed a similar green for the inside of the cab of this Bowser PRR A5 switcher, built for a friend…
…and I believe it was used for these large castings, too…
