My wife purchased for me a the Woodland Scenics Grand Valley HO Layout kit along with the Atlas rail kit. The rail kit includes 2 switches and an X crossing. I would like to make to use remote control to change them. I would like to use DCC on this setup to run 2 trains and to control the switches. I would like some recommendations for a DCC system and other electronics for the switches?
Picking a first DCC system is a mixed bag. The good news is there are 4 or 5 main players in the arena and all are pretty good. The other news is most of us are very subjective as to which is best.
After 50 plus years of playing with trains, I finally converted to DCC a few years ago. I narrowed the selection to either Digitrax or NCE. Both have quality products and have a line-up for all needs. But to ask someone which is better reminds me of the old “Ford vs. Chevy” discussions of my youth.
Check out their websites and you will find that each has a terrific entry level set up.
Visit some trains shops, train shows and clubs, if possible. I chose my Lenz system in part because I like the throttle. That is your interface to the system, so you should make sure you’re comfortable with the one you choose. Although any decoder-equipped locomotive will run on any DCC system, the same is not true for throttles. If you buy a Digitrax system, you will have to use Digitrax throttles, and the same goes for NCE, MRC and Lenz. So, make sure you like the throttle.
One common misconception of running turnouts with DCC is that you must use DCC to run them. That’s not true. While you can use your throttle to control your turnouts, you don’t have to. You can use a panel-mounted toggle, just like in the old days. Or, you can wire things up to use either a panel or your throttle. DCC gives you more options without taking away the old ones.
Operating two locomotives simultaneously on a small layout w/o an “X” crossing is challenging enough. Add the "X’ crossing AND keeping track of both locomotives (so that they don’t crash into one another) can become nightmarish. Add tunnels (i.e. limited views) and it’s an accident just waiting to happen.
With that kind of scenario, using your throttle for turnout control is not very advisable because it doesn’t allow you much of a cushion when needing to make quick decisions - i.e. avoiding inadvertent “cornfield meets”. Remote turnout control via momentary switches would be much more advisable. You want operating your trains to be an enjoyable experience; NOT a mental workout every time you rev up the throttle.
All good points here, but if the OP is looking for a quality DCC starter system, I say, look no further than the NCE Power Cab, and then in time graduate up to the NCE Power House Pro. At that point, the Power Cab can be used as part of a more sophisticated system.
Everyone will recommend the system they use. After all, that is why they selected it. No one else knows what YOU need or desire.
I have the Digitrax Duplex Super Chief. I started with a Woodland Scenics River Pass built for the grandchildren’s Thomas the Tank Engine. It has grown into an 18x20 around the garage layout including a subway. I operate my switches via DCC because of it’s ability to run routes. (Some systems call them macros.) When I want to access track 3 in the yard, I press switch “3” and the DCC system sets all the switches in the yard ladder. I also use detection to operate 3 grade level crossing signals.
Several years ago I bought an 8 amp large Digitrax radio system. 2 years ago I bought another Digitrax system–Zephyr Xtra. I like Digitrax because of the loconet and their large throttles each have 2 knobs for controlling trains. You can use a DT402D for example with the Zephyr Xtra through loconet. I made my own extended cable but could have added a radio interface UR92 since the DT402D is radio too. Of course you can use the Zephyr without the extra throttle too, lots of flexibility.
I would either get Digitrax or NCE depending on what you want and who can support you if you need support. Buying from a good LHS can help, I certainly did and do so now. I do not like the thumb wheel which NCE uses.
When I studied the options for conversion to DCC, it came down to Digitrax and NCE. At that point, I began asking questions on this (and another) Forum, and did a lot of research, but still I was undecided.
Finally, it hit me… let’s check out what the folks with published RRs use!
Sooo, I pulled all of the issues of Great Model Railroads (I have them all) and went thru each one, quantifying the DCC system used. Over all those years, Digitrax was the clear winner, with NCE running second… Sooooo, I jumped in and got the Super Chief system, and have been very happy with it. However, all of my decoders are NCEs.
This topic seems to be a weekly debate that always ends up in a battle between NCE and Digitrax users. Mr. Beasley has already given you the best advice. Do not pick the system but instead pick the thing you will handle and use to control the system. There are many more than Digitrax and NCE. There is CVP and the easy dcc system, http://www.cvpusa.com/ ESU and the ECos system, http://www.esu.eu/en/products/digital-control/ecos-50200-dcc-system/what-ecos-can-do/ Lenz with two systems, http://www.lenzusa.com/ MRC and their Prodigy systems (Not recommended by many for a variety of reasons) And slowly forming but looks interesting, Railstar. http://railstars.com/
Controlling turnouts, turntable pits, and other accessories can be done with your hand held throttle. Many find it cumbersome and confusing while operating trains. Our club uses a dispatcher to operate the mainline turnouts through a control panel. Local and switching ops are done using the brakeman in three man crews or the conductor on two man crews for all other turnouts. We did try the throttle control turnouts for the dispatcher but he lost sight of indications when it got busy and actually slowed up operations. I have seen layouts that are computer controlled from another state and right in the same room.
The choices are many and varied but it still boils down to how it fits in your hand. My favorite throttle is my Lenz LH90 but the power cab I have at home is the easiest to use.
I have the ESU EcoS system and wireless throttles, but would I recommend it ? … probably not. Total investment would be more than your 4 X 8 layout with all the engines and rolling stock combined !
That being said, I regularly run on a number of layouts that have a mix of Digi-trax, NCE and CVP Easy DCC. All the systems are wireless, and for the most part, all function as expected. But again, they are all overkill for a 4 X 8 layout with a couple trains.
To be perfectly honest, even though they get downplayed a lot, the MRC system really isn’t all that bad. I know three different small layout users who have the MRC Prodigy system and have never had a problem with it. The hand helds have a knob throttle which a lot of new users prefer in transitioning from DC to DCC. Plus, the system won’t break the bank if you are just testing the waters.
The advice I give to any beginner is to use as many systems as possible and decide after having some experience. Ergonomic preferences vary between individuals, so one person’s favorite may not work as well for another.
All of the major systems work fine (NCE, Digitrax, Easy DCC, MRC, Lenz). Choose one of those that you like and you really can’t go wrong.
I did an informal count of systems while I was visiting layouts during the GSD (Garden State Division) MNRA fall meet a few weeks back. Most of the home layouts used NCE but they also said MRC was worth a look.
This is the Ford vs Chevy vs Dodge vs Toyota vs Nissan vs Honda etc debate.
Generally speaking I agree with those that advise to get the system with the controller that feels most comfortable for you. But, overlaying that advice is to consider what other modelers of your acquaintance are using. If you have the same system of at least one or two of them, they can become your support team.
I also (last year) got down to Digitrax vs NCE for my new HO layout. I don’t think you can go “wrong” with either as many like one or the other. Above advice is useful; e.g., try them out.
Do recognize that some auxiliary track power items, if you need them, are independent of the brand of primary items you buy (source power, controllers). As an example, I wanted 3 “subdistricts” (needing circuit boards) downstream of my NCE system (2 with reversing loops, one just a subdistrict circuit breaker) and found I could choose from several non-NCE items.
On turnouts, decide on how you want to control them (through the DCC system or otherwise). I decided to build a schematic turnout control panel ala an MR article, using DC power via DPDTs with LED turnout position indicators. I love it, and thus do not regret not bringing the turnout control approach into my DCC system decision.
I did enjoy consulting with Tony at Tony’s Train Exchange to ensure I understood the decisions I made at the time.
ZIMO is not very well known in North America, and doesn’t seem to really be pursuing the North American market; thus they have very little support available in the U.S., from what I have been able to find.
NCE and Digitrax are made in the USA, and are serviced in the USA, which can be a major consideration when selecting a system.
I have no experience with Lenz systems to know about their service and support availability, but Lenz decoders are top-notch products that have never failed.
