It may signify different things on other railroads but I have seen this sign used on the Pennsylvania Railroad as a “Flanger” sign.
A flanger was used in conjunction with a snow plow. It had two blades that would clear ice and snow from the inside, flange area, of the rails. The flanger blades would have to be raised at switches or other obstructions, thus the sign to alert the operator.
A snow plow or flanger has blades that are lowered between the rails to clear out snow and ice. If this were to hit obstructions between the rails (crossing timbers, switch point rails, bridge guard rails, etc.) there would be serious damage caused.
The flanger signs are placed at a certain distance ahead of these fixed points to warn the plow/flanger operator to lift the blades so they don’t impact on the obstructions.
It doesn’t warn other people that a plow or flanger is in the area…
I have never seen the triangle sign used for a crossing except where, for some concern in the crossing’s geometry or construction, a flanger would have to lift blades or some other equipment concern would have to be observed. It is NOT a replacement for the W whistle posts and doesn’t convey the same meaning at all.
It might be interesting for someone who has (or knows where to hot-link) images of the markers steam railroads with track pans used to indicate both ‘scoop-up’ near the physical end of the pan and where, on a double-headed consist, the lead locomotive should lift its scoop so the second one could take water.
I know there was signage of some sort telling crews of locomotives with track pan scoops when to drop and when to retract, but I’ll be dipped if I can find any pictorial examples of the same.
The closest I’ve come is this article by the New York Central Historical Society that shows track pan limit lights, purple in color, on New York Central pans.
Vince, a few years back I read a “first-person” article in “Classic Trains” where the author told the story of a cab ride on a NYC locomotive, he was a teenage railfan at the time and his father arranged it.
Anyway, he was enjoying the ride and soon the locomotive was coming up to a track pan. The fireman gently pulled him into the center of the cab and then positioned himself by the scoop control. The engineer yelled “Down!”, the fireman dropped the scoop, and then our young rider found out why he was moved to the cab center. During the scooping process he said the whole cab shook like an earthquake and the roar was incredible!
Not so much the air pressure itself as the hydrostatic shock (think 'water hammer on steroids) of the flow directed by the confined air in the tank. Interesting flow control in the 80mph PT arrangement, and probably even better still in the planned 44ton arrangement.
I was amused to see Lionel getting extra ‘play value’ out of its latest grossly-overpriced ‘toy’ engine by simulating this system with fans and smoke generators. Apparently it is not very convincing if you’ve seen the real thing!
Those high-end O gauge scale Lionels and MTH’s, among others, ain’t exactly toys, not with those price tags. Not toys for children at any rate.
I sure can’t afford 'em, and even if I could I’m not sure I could bring myself to spend the money. Obviously there’s a market for them though.
I’ve been pursuing post-war Lionels myself, they’ve gotten very reasonable in the past few years and they’re easy to repair once you know how to do it.
Here is a drawing of a snow plow truck with flanger and ice cutter blades showing. Since the flanger protrudes below the rail head it may snag on frogs and points of rails.
A distinctive and easily recognized sign is placed for the operator to take heed and raise the blade before the blade causes damage or contributes to a derailment. The print says sign shall be placed forty to fifty feet before the point of obstruction.
Some designs of flanger blades incorporate shear bolts to allow the blade to swing clear of the obstruction but if ice or hard packed snow is in the machinery this may not be enough.
