[?] Would anyone happen to know right off hand what the frog number for the PECO SL-E190 double slip switch? It is a code 75 streamline one in the yellow box. The paperwork doesn’t seem to say, or I missed it somewhere.
TIA.
TIA.
It is 12 degrees according to the Peco product site. This is between a #4.5 and #5.
Mark
off hand it looks simular to a number 6 that i have. i plan to check it out when i get home tonight.
Not an answer (since I don’t know) but a way to find out.
Draw a straight line on a piece of paper longer than the assembled DSS. Place the DSS on the paper with one rail of one straight-through route aligned with the above. Mark the location of the ends of one rail on the other straight route. Connect the dots, then find the point where the lines are one inch apart and measure back to their intersection. The number of inches will give you the exact frog number.
The prototype uses the same method, in feet, to determine frog number of ‘heritage’ specialwork.
Chuck (modeling Central Japan in September, 1964 - with hand-laid specialwork)
OK, Thanks to all that answered. Guess I should have checked the Peco website. I’ll have to remember that one.
