What is happening with Micro Engineering?
Hi gang,
I have been trying to find the Micro Engineering Home website but I am drawing blanks. I can find a couple of pages listing some products but there is no Home page connection.
FWIW, I am trying to find a piece of HO scale Code 83 bridge flex track #11-101. Almost everyone seems to be out of stock. I did find a couple of suppliers who say they have it in stock, but their shipping prices to Canada are not worth the money.
Anyone know what’s happening with ME?
Dave
Dave
Their site is working. Not very good but working.
Home Page
http://microengineering.com/index.htm
Click on Flex Track, bottom of the page has the bridge track listed.
http://microengineering.com/products_ft.htm
Mel
My Model Railroad
Bakersfield, California
Flash player is going away, ME needs to fix their web site.
Sheldon
Hi Mel,
I have been able to get those two pages but I can’t do anything with them, i.e. try to place an order.
I hope they are not on their way out! I hope Sheldon is right when he suggests that it is just out of date website software.
I have said to myself several times that if I ever win the big lottery prize I would spend my money buying up all the model train companies that are going out of business due to retirements or whatever. Unfortunately, I’m not sure that the odds of success would be in my favour. As others have said, “if you want to make a small fortune, start with a big one”.[swg][(-D][(-D][(-D]
Cheers!!
Dave
I also need code 83 ME bridge flex track. None of my usual suppliers have any.
-Kevin
Dave,
Their website has always been awful…I wouldn’t make too much of it
Guy
Hi Guy,
Yes, I remember not being too impressed with it in the past, but now it seems to be barely functioning. Oh well, I guess we will all just have to be patient while they sort things out. Hopefully they will do that soon.
Dave
ME is like a lot of small manufactuers - they “batch build”. So once they finish a run of one product, they will do another. Probably haven’t done any of the bridge track for a while, maybe due to runs ome again. Depends on what’s popular - if they are selling a lot of the ladder track system they may be making that.
The web site has always been a bit how ya doin’. Clearly they are not spending money on a top notch web designer, more likely they are just doing it themselves. Consiodering how long they’ve been around, plus they advertise in all the major hobby pubnlications, probably no need for anything fancier or expensive.
Yes, Flash is supposed to be completely going away - but so many games on Facebook and other platforms still use it, so unless they have their updated versions almost ready to go and just don’t want to release it until the last minute, a lot of things are going to break very soon.
On my last layout, I used Central Valley bridge tie strips. I cut out a section of Micro Engineering code 70 flex and glued the CV tie strip in place. Worked and looked excellent!
I just checked their site and everything is functioning fine for me. (?) I DID have to activate Flash player in the top header on their home page. Once I did that, I was able to pull up the order sheet and all the other pages no problem.
Mark.
Hi Mark,
My computer won’t let me download Adobe Flash Player. I haven’t a clue as to why. I’ll just have to wait until ME’s bridge track is available. I can use regular flex track until then.
Thanks everyone,
Dave
Micro-Engineering makes some great track (I use their flex all over my layout), but their website is still stuck in the year 1994. They are notoriously low-tech.
Hate to say this, but the best way to order from them is to call them up: (636) 349-1112.
Called Micro Engineering just the other day. They are way behind on production due to slowdowns and shutdowns during pandemic. Bridge track is on the current production plan for early 2021. I too have been looking for ME code 83 bridge track. There is some code 70 stock at TrainLife.com if that would suit your needs.
It’s built in to CHrome (and the new Edge, which uses the same basic engine). You may have to change the setting so it prompts to run Flash instead of outright blocks it. On Chrome it’s under Settings, Privacy and Secutiry, Site Settings, Flash. Just change the switch to Ask First.
Google can posture all they want, but given that pretty much all of Facebook Gaming runs on Flash - if they really disable it permanently at the end of the month, they can kiss any chance of holding the browser market goodbye.
Worth noting maybe that they haven’t updated the site in 6 years.
I was under the impression that Adobe was retiring Flash and that’s why browsers are dropping support.
My work PC just had an update pushed today that uninstalled Flash because of it.
How much of it do you need, Dave?
I need 32" (4 x 8") for four short plate girder bridges. That will give me about 1.75" either side of the bridges.
Dave
I have two pieces of ME bridge track at about 7" each, and one piece of Central Valley bridge track at just under 4". The main difference between the two brands is that the “woodgrain” on the ME stuff is a little more pronounced and also has guide nubs for the inside guard rails. I have lots of the outside “wooden” guard timbers if you need them, but no code 70 rail for the between-the-track guard rails.
If it’s of any use, you’re welcome to it. Send me an e-mail if there’s anything else you might need.
Hi Wayne,
Thank you for your very generous offer!
I’m not in any hurry for the bridge track so I think I will just bide my time until ME makes it available again. In the interim I will just use regular flex track.
I’ve been in a rut for a few weeks. I have to get my butt in gear again!
Cheers!!
Dave
The website apparently hasn’t received any TLC since 2014.
