The accident on the way to work scenario happened to me, so…
Was rear ended at an intersection by a woman on her cell phone, she tagged the rear of my Magnum in her Mercedes SKE at 60mph…the SKE didn’t survive, the driver did.
Called the crew caller and was marked off as having called a “relief” which is railroad jargon for marking off after accepting a call or while on duty due to illness, emergency and several other reasons…
Look at it from this point of view, I had accepted the call for work, and while I was not technically on duty, I was on the way there within the 90 minuet call frame, so the carrier has the right to expect me to show.
Because of circumstances beyond my control, I could not report, so I too have the duty to inform the carrier of such, hence I was shown as having called a relief instead of missing a start time.
Most railroads with union contracts work it this way, but if you abuse the system, they will and do fire you for it.
As Paul and other noted, the job requires, for the most part, a willingness to show up no matter what the weather or time, and be ready for duty as soon as your rest time is up, the physical part can be grueling, but it rarely is so tough that a person in reasonable shape couldn’t handle most of it…yes, you will have to pick up a 90lb knuckle every once in a while, but that’s the exception, not the rule.
Riding the cars, being able to mount and dismount them, and tying hand brakes/lining switches is the normal daily duty…most of the job is mental work, trying to figure out the fastest, easiest and safest way to perform the work, plus the fatigue factor when you work in pool or extra board service.
That will be the hardest part of the whole thing, the lack of quality sleep and relaxation, plus the time away from family.
If she can handle those, she can handle the rest.
