This was an impulse purchase at the Atlanta Train Show last weekend. This massive beast was only $5.00, so I snapped it up not even caring what it was.
It is a 16 axle super heavy flat car. The load is awful, so it will need to be replaced, but that is an easy fix.
Well, now that it is home, I am not sure what to do with it.
It will never be able to run on my layout. It is just too darned big for my hidden curves.
My gut feeling is just to repaint it, letter it for the STRATTON AND GILLETTE, and use it as prop in photographs. That was my intention when I bought it.
However, I am already looking for ways to improve it. The end sections are made of wood. The depressed center section is metal. I don’t think there is an easy way to get enough weight on the end sections for it to track reliably.
I am just pondering really. It is a neat model. I might take some test pictures tomorrow to get an idea of how it looks in a model setting.
I guess fix it up and use it as a photoprop or part it on a siding somewhere to add some variety to your rolling stock fleet. Maybe fix it up and but it in a diplay case somewhere in your layout room.
That thing really is a monstrosity! What is the minimum radius on you layout, I think it may fit a 28" or 32", maybe. Have you tested it to see what it will handle. Maybe you could modify it to handle tighter curves, perhaps replace the truck with 4 3 axle trucks or 8 2 axle trucks…
I don’t think a car like that would be in a regular train, all the pictures I’ve seen (which isn’t that many…) of cars like that are in short trains often containing just the car and a caboose on either end.
Whatever you do with it you only spent $5 on it, so if it sits in a box in the basement I guess it’s not really a big deal…
Gidday Kevin, because it would bug me, because it’s a part of the hobby that I enjoy, and because it’s a challenge, I would get the car running properly even if it requires rework, though knowing me I’d study those photos and drawings in Toms site, and get totally carried away. [banghead][banghead]
You don’t need me to offer any troubleshooting advice, but at the worst you could do what you say, letter the car for the S&G, though I’d paint it gloss white, so that the Stratton & Gillette staff could call it “Kev’s white elephant” behind the Owners back.[:P]
Have fun.
Just a little depressed centre car.[swg] CSIX500 by Bear, on Flickr
Cheers, the Bear.[:)]
Kevin,Don’t worry about extra weight because those long SD cars was used wth a ideler car behind the engine and in front of the cabin…When empty they was the last car of the train consist…
Obviously taken the same day as the Wellsville, Ohio shot. The PRR also had an open-well span that could be substituted for the depressed center portion. I believe the car was used 98% of the time for hauling Westinghouse power plant turbine assemblies.
Some of the models made by Railworks will command upwards of $600 when they come up at auctions or brass dealers. As far as what to do with it? Perhaps make a small display shelf for it and keep it as a conversation piece.
Yes the Pennsylvania RR had such a massive flat car, and as I recall the four axle trucks were taken from retired and scrapped tenders to the T1 class 4-4-4-4 steam locomotives. Those were huge heavy tenders. Whether Bowser still offers those trucks (old Penn Line tooling) among their remaining steam parts (they advertise that they still have some steam parts) I do not know.
There was an article in the 1950s by an excellent modeler of the era named Irv Winer, who was one of the first to take up the challenge of modeling in plastic at a time when the “real” craftsmen in the hobby disdained plastic. As I recall Winer used acrylic plastic and heat formed it over his own crafted wooden form to create one of these massive flat cars. I wonder if this could be that very model? Or built by someone who was following the MR article?
And if I recall correctly the late Gordon Odegard was modeling the same car in the same old issue of MR but he used wood and metal for his model. As good a craftsman as he was, I recall Winer’s model looking far more like steel, but both models looked great.
The thing about flatcars of this huge size and capacity (which would need special orders and routings when used) is that they likely spent most of their lives sitting on a siding in a yard somewhere waiting for just the right customer to need such a massive car. So it would be quite prototypical to have such a car shoved onto a siding, perhaps even a weed grown siding, and not run it on the layout. Sans load of course. Now and then you could just remove it from the layout and claim it was sent to an online customer at a time of day when - by astounding coincidence – nobody was in your basement to see the move.
The model is not really an accurate model of the prototype shown, as the end decks of the depressed-centre car are too short, placing the weight of the car and its load on only the in-board set of trucks .
On the protoype, that weight is applied to the centre of span-bolsters over the two trucks at either end of the car.
Were it mine, I’d remove the outboard trucks and the deck extensions over them, then either lengthen the car to extend it over the remaining trucks or remove those trucks and replace them with a pair of short-wheelbase three axle trucks.
While at first glance it looks impressive, there’s a lot about it that’s not right. Modified as suggested, it would not only look more believeable, but would likely also be useable.
Kevin, put a big wooden crate as large as you can possibly fit in the middle of that thing. That would conceal what’s in the crate.
I would say that flatcar was used to transport Gold from Fort Knox to Area 51 for the aliens that have been harvesting it from our planet since the time of the Egyptian pyramids.
If I’m right… it could be why that flatcar was designed and why our money is not worth anything anymore[(-D][:-^]
TF
Gold is heavy… it’s all about weight distribution.
I have limited knowledge of such flat cars, but I do agree that the configuration isn’t realistic. The load should be bearing on both trucks equally. That will require extending both ends of the main body, but if you do make the changes, as far as weight goes, you would be able to put all of it into the load.
Given that the main body is metal, you might have to build your own extensions unless you can find a matching depressed center flat car by the same manufacturer. Even then, cutting the bodies up and mating them properly might be a PITA, and if the glue doesn’t hold, you will have a disaster on your hands. As an alternative, you might try finding a couple of Athearn depressed center flats and making an extended body out of the two of them. It would be a lot easier to glue styrene sections together rather than metal. Or, scratch build your own body like JaBear did.
Thanks for posting the real thing. You are correct my dimensions are only off a few inches, because the car in the picture is at a slight angel I had to guess at the length.
I filed the drawings in my railroad CAD folder for future reference.
I’ve been to Altoona and seen the real thing - pretty darn impressive piece of heavy machinery. It does tend to look oversize compared to more typical rolling stock, so it’s a great contract. As Dr. Wayne pointed out, the model is just not right, and it really sticks out even without seeing the prototype comparison.
Now that I have taken a better look at the model, yes, it is too far wrong to even use a prop without some work.
The ends of the depressed section should end in between the two trucks for it to look right, and they do not.
However, the trucks do not look too terrible when compared to the prototype pictures, and they are brass, but I do not know the origin.
The end platform sections are scratchbuilt from thin balsa wood. That is why they are so light. One of the ends is terribly put together. The trucks interfere, and that is what caused the car to lean. There is no way to get all the wheels to sit on the rail, so at least one axle is always sitting on a flange and being raised up.
The other end looks pretty good, but not able to be used.
The center section is from AHM.
My idea is to use only one of the four axle trucks under each end. I will build small platform section for each truck. I might machine the platforms from bar stock steel for some weight.
I think I can use these pieces to build a good looking freelanced heavy duty flatcar.
I will politely disagree. It is pretty obvious that the truck is twisted. It looks like the trucks are screwed together, which is typical of brass construction, so if you loosen the screws slightly the sideframes should be able to be adjusted to be parallel to each other. I’m no expert on brass, but perhaps the sideframe screws should be slightly loose to allow the truck sides to float so they can conform to the track independently.
Your idea of just using two trucks instead of four is certainly workable, but the end result will be nowhere near as interesting as the original model. You have a great opportunity here to make a real silk purse out of a sows ear!
If it were me, I would stick with 16 axles. You implied that you have access to machine tools so you have the resources to make the articulated truck system parts out of metal. I don’t have much in the way of machine tools (read - none) so I would just make the articulated platforms out of brass stock. That would address the weight issue quite nicely! I’d also forget the metal body and follow JaBear’s example of building a depressed center flatcar body from scratch using styrene. It could also be done in brass, but styrene would be much easier.
