In reference to #418: The PRR tested several locomotive designs prior to the opening of Penn Station and the DD-1 showed significantly lower impact forces than the other designs. Reasons given for this were the asymmetric wheel arrangement and high center of gravity. The DD1 wasn’t that early of a design as it was contemporary with the BA&P locomotives. While the ca mounting of the motor was unusual, it did allow for less compromise in the proportioning of the motor than with nose suspended motors.
One reason that this isn’t completely off-topic is that the PRR testing showed high center of gravity can be a good thing in locomotive design.
In order to get this thread back to the original topic, while browsing Will Davis’ blog, I came across this. Since Juniatha mentioned a possible Alco 2-12-6, I found this interesting. Perhaps Will Davis will explain more?
I read the Will Davis blog, it’s interesting to say the least. Mention was made of clearances, very wise since the line drawing reminds me of a pregnant sperm whale! What I’d be concerned with is track curvatures, it would seem to me a 2-12-6 wheel arrangement would be very limited as to where it could go.
Remember there were places, quite a few, where the UP’s 4-12-2’s couldn’t go.
I had seen a sketch of this locomotive before , unfortunately it did not show anything about this special cylinder / frame connection or the rods arrangement ; what it did show was this awkward position of cylinders overhanging the front end and the rudimentary pony truck , a drawback to times long since gone by when - much-much smaller engines ! - had shown inadequate tracking because of insufficient guiding of the leading axle . Further , drive to the second of six axles must inevitably cause larger than necessary forces in intermediate coupling rods , an hitherto unseen extended sequence of coupling rods causing increased wear and summation of bearing play , increased chance for misalignment of axle and rods gauges … and more .
I should add as to the story I had read , this had been a proposal for C&O when they had asked for an engine above their 2-10-4 ; the proposal was rejected and in the following design was changed into the known Allegheny SE Mallet type . All in all a single twelve coupled with but two large cylinders certainly would not have been an edifying design and a double six coupled engine having four cylinders was the right choice back then .
In my view a twelve coupled engine would have been practical - yet only in combination with a three cylinder layout , further developed from the level attained with UP Nines where namely the inside drive arrangement was not fully up to demands and conjugated Gresley gear caused high forces in outside Walschaerts and with play - the usual dirt abrasion theme which so plagued steam - produced awful valve events in middle cylinder .
Increasing cylinder volume was one thing - what mattered was piston force and longest possible stroke in relation to wheel diameter to produce maximum torque at wheel rim . In that respect the ATSF 5000 class Baldwin 2-10-4 did already exploit then technical limit pretty cl
yes , pretty much so ; it was understood elder engines were withdrawn earlier than later power of the same capacity , yet the Nines had longer working life than many other engines , namely the BigBoys . If so , you might conclude they had been more successful as they accumulated more miles in longer service life - yet that would be misleading since life span of BigBoys was largely determined by advancing dieselization .
you cannot conclude on degree of UP Nines’ success by the fact BigBoys were built , nor UP switched to SE Mallet instead of straight frame three cylinder power . An engine concept incorporating four outside cylinders was potentially offering a wider scope for development of power than a straight three cylinder type . However , more aspects played their obvious or obscure roles in making decisions . I already hinted the Nines had been quite successful - especially in view of gross neglect and still remaining in service for years on end - however they had not been as complete a success as they could have been without ailings namely of Gresley conjugated gear , built-up framework ( only the last batch had cast steel engine beds ) and various other minor flaws . To be fair , this class of locomotives had been sort of an ‘intermediate’ as development went from conventional power of the times up to the 1920s to later high performance power . You can see more evidence of progress advancing by design changes incorporated in series of Challengers as they continued to be built . BigBoy on the other hand clearly was a loco class of larger power capacity than the Nines - early Challies were not , as I had asked for discussion in my earlier thread about the Nines / Challengers .
And yes , even if the Nines had been completely successful time would have passed them by and larger locos would have
Did the 9’s with cast steel beds stay in service longer than fabricared beds? Were any 9’s with fabricated beds rebult with cast steel? When was the very last major steam locomotive in North America built with a fabricated engine bed? (Approximately if no one has the exact answer)
No , I think not ; afaik Union Pacific joined the bandwagon with other railways never to care much about sorting out individual engines of earlier batches and seeing to keep the last / best ones of a class . For one reason , decisions on keeping / ending service of steam locomotives often were based on local service or district line running , that is : engines of one class could be laid aside at one engine facility while others of the same class continued at another shed handling traction on another line . Since engine swopping between sheds had always been a never ending activity , hardly one shed could assemble a group consisting but of one best suitable / latest built batch - regardless of any progress realized when building these various batches . For instance , on DB the last shed maintaining 01 class Pacifics - Hof , Franken , near the former border to the Eastern Block - never had a roster consisting but of reboilered 01 , neither had they rejected reboilered engines to keep but the original ( Wagner- ) 01 - each which way would have had its pro and contra part / part since imho DB Witte reboilering of 50 engines 01 class should be considered but partly successful , having shown drawbacks of its own . DR was more to the point by concentrating their last Wagner-01 engines in Dresden-Altstadt while sheds of Erfurt , Magdeburg and Berlin-East had but 01.5 engines , i e 01 rebuilt with high capacity boilers . Ironically , during the very final years last survivors of both variations of 01 engines were re-united at Saalfeld shed - a typical expression of late hour steam traction when hitherto valued advances in performance or maintenance upkeep had become meaningless since the remaining engines were handling but easy enough services without having to be fully extended .
The first thing I noticed when looking at this locomotive was that there would need to be quite a bit of play in the driving axles to let it negotiate any type of curve. Maybe even swiveling them like the first driver set of a SE Mallet and having a rigid front truck?
Maybe even swiveling them like the first driver set of a SE Mallet and having a rigid front truck? <<
Oooopset ?
How’s that supposed to be ?
Puzzled ragazza
Juniazza
No , really I don’t see why major well-proven set-ups would have to be up-set only because there is another drive axle introduced . 2-12-4 types - if as tank engine , yet that doesn’t make a difference as concerns length of coupled wheel base and overall w/b - worked in Bulgaria and did so on mountain division abounding with sharp curves : they didn’t need to carry their leading truck ‘swallowed’ - see description and small picture at
Design of lateral motion has to be specially adapted to w/a - yet the idea is pretty much the same as in the Harz 2-10-2 negotiating 50 m radius curves !
With a mainline 2-12-4 no flangeless drive wheel set should be necessary , UP found that out in their Nines .
BDZ 46 class preserved in running order or cold ?
Dunno - I guess preserved engines vary between warm and cold from time to time - not only but also in Bulgaria.
According to Rob Dickinson, they are in the strategic reserve at Asenovo, not operating but under cover.
The leading axle on Woodard’s 2-12-6 is positioned where it is to shorten the wheelbase to permit shorter turntables. I wish Mr. Davis would post the whole text of Woodard’s presentation, as it makes many things clear that are not well recognized from just looking at the plan and elevation.
This design comes at a very interesting time in design history, when the ‘correct’ design paradigms for large high-efficiency locomotives were not as well recognized as they were even by 1931, or even the practice of the AMC in its Berkshire and Texas designs. Lima itself would come to find that driving on the third axle, with longer stroke, would be a preferable approach to the ‘unitary machinery support’ approach with large cylinders set close together … and I think it pays to consider why.
One amusing note is that the proposed locomotive retains the articulated trailing truck, which might explain some of why Woodard drives with high angularity on the second coupled axle – the first Berkshires with this truck were notorious for bad riding, as the articulated design did not correct nosing nearly as well as the later “bissel” Delta trailers would. This behavior would have been well recognized by 1928, and here we see Woodard either calculating or assuming that the nosing moments would be so reduced as to make the much greater piston thrust … and lower resistance to nosing moment given by the ‘inside’ lead truck … not pose a major issue.
Interesting to note that essentially the entire history of high-speed articulated locomotives lay years in advance at that time, so the superiority of a
Uah-well , you’d be slightly disappointed , I presume , if you went there with expectations as big as that ( but then again USAir might ask you to pay for extra luggage when you want to board with that huge a cloud of imagination looming about you - gg
It was a tank engine on second glimpse featuring a somewhat astounding number of powered wheels in a row - but then again not so astonishing that it would make you dizzy or only look twice . On the contrary , it gets pretty normal looking in a short time . How do I know ? I haven’t seen one in reality but I have enough photos of them and in relation with photos of the various Decapods that were roaming the Bulgarian Railways and so closing eyes I can just imagine … and there they are - somewhat longer than a T20 DR 2-10-2 ramp tank engine , somewhat less well proportioned , always the question which one to prefer : the two cylinder version with inside frame rear bogie - the outside frame bogie three cylinder version ? the boiler full size of that of a Decapod - no they weren’t without power and bulk of their own - and in this strange , remote landscape , in these very blackish steam sheds where green Decapods with red wheels stood off the general air of black soot and cinders …
Only , what was the exhaust ? I don’t know , except for I can guess it was pretty rough , although originally the type of draughting pretty much was that of the DR standard types of steam it had long since become ‘bulgarized’ considerably - all railways of the South East of Europe tended to sharpen draughting plus they tended to add strangely primitive nets on or in the chimney to fight spark throwing …
I had forgotten how different the exhaust of a three-cylinder locomotive is from what we consider nromal. This reminded and presented some wonderful experiences.
The discussion of the PRR S1 on another thread makes me wonder, what about a duplex class for the SP&S? They had a pretty straight and flat line, and had big 4-8-4s. Also, they had extremely poor Cascades coal. So, what about a 4-4-4-6? Or would a 4-8-6 be better?
