I’ve asked this elsewhere, too, where I saw a discussion on a different forum a while ago, but I’m getting answers that don’t seem fully commital, so I’m back on the home rails, as it were, with my question.
I have several craftsman structure kits – Campbell, Durango Press – with thin wood walls. I want to paint them before I assemble them, but I’ve often heard that acrylic paints, being water-based, will warp the wood. I’ve heard I should use lacquer-based paint instead. I’ve heard I can safely use acrylic if I seal the wood first with an acrylic sealant. I’ve heard that it’s okay to let the wood warp before assembly because I’ll clamp it down anyway during the build. I’ve heard that enamel paints (Testors) will work fine, maybe.
I’d like to find something approaching more of a consensus – I think every man jack of you has built craftsman wood kits before. What paints, sealants, thinners, concoctions, tinctures, witches’ brews or other methods do you use to make sure the walls don’t warp? If any two of you agree on something that works reliably, I may follow suit.
Thanks in advance,
-Matt
