Is it dirt? Ballast? Concrete with a lube well?
Likely to be dirt, flagstones, or wood blocks, but if it was “modern” it might be concrete.
Welcome back, Spacemouse!
Good to see you back, Chip!
I’d have to agree with Mike on the floor being either dirt or wooden blocks, as both would stand-up well to abuse, especially dropped heavy items, such as side rods or wheelsets. Both types of floor would be relatively easy to repair, too…a shovel for the dirt, and removal of damaged blocks, with new ones installed.
Scroll down to the machine shop part in this LINK, as it confirms my recollections that the blocks were installed with the end-grain up, acting as the floor’s surface.
Thanks, both of you. I had assumed dirt, but I really didn’t know. Good to be back.
Dirt is a good starting point, easy to model.
A shop that was there longer (being the 1890s, it might be new or only a few years old) might upgrade to the wood blocks. In fact, it would be a neat scene to have a dirt-floored shop with “remodeling” with wood blocks underway starting in one corner of the floor.
Also, if modeling a logging line, the material for a wooden shop floor would be readily at hand and thus make it more likely that its facilities used wood blocks.
Right where the tracks are would likely be wooden planks over the ties, so there’s another variant thing to consider.
Chip … Good seeing you.
My old engine house is made from a Campbell kit, and it has a wood floor.
This is part of a 1900 era scene in one corner of my layout. I saved several items from my previous layout, and I decide to make the scene from some of it. The rest of my layout is about 1960.
if it’s 1890s origional, it -might- be two to three inch with dovetail, interlocking hardwoord floor …
I’ve been through a few New England mill buildings, and was impressed with the vertical-grain block floors. They looked very durable and easy to repair.
How might one represent such a floor for modeling purposes? I shiver at the thought of cutting and gluing a million 1/16” long pieces of scale lumber! [%-)]
Jim
I worked in a Stamp plant, and plastics molding plant from the eary 1980"s to 2004. The floors were three inch pieces of two by foor wood. Standing on end. They were placed on concrete that was a foot thick. The wood absorbed shock from dropped heavy objects, and when damaged could be quickly replaced. As a bonus it also adsobed oil spills, without becoming slippery.
I would assume the floor would be wooden, but if it belongs to a very poor railroad, dirt would be possible.
The flagstone floor that was suggested could make an interesting model.
-Kevin
Wood block. The blocks are standing on end, with the end grain up. You could use cobblestone sheet or “tile” sheet. Most of the wood floors I saw were 4x4 or 6x6 chunks.
The floor has to beable to absorb impacts and stuff weight several tons over a very small area being set on it. For example a set of drivers would weigh several tons and rest on a total area less than the size of a hand.
A dirt floor would be really messy, steam engines involve water, grease and oil, mixing that with dirt is a goey mess.
I agree with David, when I was a kid in the 50’s there was still a railroad yard in Taylor PA, known as Hampton Yard that we explored. There was a roundhouse along side the yard that was scrapped along with the steam locomotives of the Lackawanna Railroad in the early 50’s. The remnants of that roundhouse has floors exactly as Dave described them. In some places the blocks were torn up and were only about four inches thick.Now maybe that was build around that time, maybe a bit later, but it surely seems accepted practice in construction.
Wood blocks. I worked a summer job in a foundry in 1970 and all of our buildings had wood block floors.
Ray
Thanks guys. I guess Randall “Rock” Ridge is going to want only the best.
I have been trying to find a photo I have where the floor was dirt and wood blocks, looked like RR ties cut up. They had pits and the walls of the pits were definitely RR ties as was the floor.
Garry, great looking layout and engine house.
Okay then. Any one of you modelers have an idea of how to create a block floor. I too dread a million 1/16 inch pieces.
The best I can come up with so far is using popsickle stick end cut, Then sand them smooth and spray with dullcote. Then score the ends to create square blocks and use a dark wash to highlight them. Add some grime and Voilà!.
Still, I"ll need to take out the detail work on my benches and redo that.
I would cheat. Just like those airplanes that you’d ‘dope’ with a pre-printed tissue paper covering. Make up a scale image of an end-grain floor, glue it in place, tool the surface a bit with a burnisher to give it texture. It’s not like it has to take proportional load or shocks…
N scale brick sheet?
https://www.rail-scale-models.com/N-Scale-Common-Brick-Wall-Sheet
FWIW,
The East Broad Top roundhouse floor is Gravel on Earth:
https://www.loc.gov/resource/hhh.pa3371.sheet/?sp=1
Here’s a photo of end block oak that you can use in a photo editing program to copy>duplicate>paste and print:
Are you familiar with vector-based editing software? (CorelDraw or Affinity Designer?)
Wood-block by Edmund, on Flickr
Cheers, Ed
