I know. The question has probably been brought up a hundred times, but if so, I missed it if it was…
So what year did steam locos begin using oil for fuel ?.
Tracklayer
Tracklayer
around 1800, from the very beginning wood, oil and coal were used by different railways in different parts of the world.
If you are asking about a specific railway, ask the appropriate historical society, and become a member.
I don’t think any railroads went “all” oil.
The NH had some Moguls oil fired for work trains service in the electrified zone.
My understanding was that oil and coal were both used up through the end of steam in the 1950s. The key factor was location. Oil was generally cheaper than coal in the West and Southwest so the ATSF was a big user of oil for steam locomotives. As for the year oil was introduced my guess would be the early 20th century. I know this was when oil started to replace coal aboard steam ships. 1800 is too early since the first oil well was not drilled until the 1860s.
Oil was mandated in many of the forest areas in the Pacific NW. Also, oil was used in areas that did not have coal reserves nearby.
Jim
I am modeling 3 lines. The Northwest Pacific, the Cailfornia Western and the Southern Pacific. The first two are pretty much all oil and the SP is oil in the part of the country I’m modeling.
Now if someone actually made oil tenders…
Thanks for the suggestion, but that’s too much trouble…
The other members that replied seem to understand more of what I meant.
Thanks guys.
Tracklayer
Tracklayer, you meant when were the locomtives able to use oil, not when the RR’s used them- i know Rock Island had coal burning and oil-burning 4-8-4’s and generally the oil burners were west of Kansas city and the coal burners were east of Kansas city. So i think it depends on the area.
Yea dingoix, I guess I didn’t take the time to ask the question in the way it should have been asked…
What I was trying to find out was when American railroads begin using oil as fuel for their steam locomotives and oil tenders such as the Vanderbuilt type ?.
I recently gave up smoking (again!.) and am on the Nicoderm CQ patch, and I feel as if I’m on a large dose of tranquilizers, and not thinking all that clear right now. Now watch some wise guy say - yea TL, well what’s your excuse the rest of the time?..
Thanks for you help.
Tracklayer
Oil tender are really not special. An oil ‘bunker’ or ‘insert’ is dropped in the coal bunker space on a tender. No ‘coal auger’ is neededt o push coal, but steam lines are routed to special coils in the oil bunker to ‘heat’ the oil up so that it will ‘flow’. Many times cheaper ‘Bunker C’ fuel is used and can be tar like or even stiff in cold weather. The cylindrical part of a ‘Vanderbilt’ tender holds the water. The Vanderbilt was a progression away from older ‘retangular’ tenders. The bottom of older tenders tended to fail and this was one of the new ideas to relieve it. A Vanderbilt tender could have either a coal or iol bunker. Later cast water bottom tenders were built and the Vanderbilt design faded(except for the lines loyal to the design).
Jim Bernier
A Vanderbilt was not always a oil carrier. There were coal and oil Vandy’s.
The NH had some coal Vandy’s.
Thanks Jim. I had always thought they used air pressure created somehow by the loco to pu***he oil from the tender through a line to the fire box where it was burned. Oh well. Live and learn…
Tracklayer
I didn’t know that. I’d always taken it for granite that if it was a Vanderbilt that it was an oil tender. I guess I need to read more and pay closer attention when I do…
Tracklayer
Southern Pacific and other west-coast lines started using oil-burning steam locomotives around 1910. Prior to that they used coal imported from the east coast (expensive) and prior to the importation of coal they used wood (cheap and plentiful, but inefficient.)
Many backwoods logging railroads kept using wood for fuel until the 1940s because it was free (it was, after all, literally lying there on the ground to pick up.)
Oil-fired locomotives both heated and pressurized their oil to pump it–the steam heat allowed the oil to flow better, but that only changed it from the consistency of tar to the consistency of Jell-O. 4-5 PSI of pressure behind the oil helped pu***he goo from the tender to the firebox.
Oil was used on the west coast and in the southwest because there was oil there and no coal. Coal was used in the midwest and the east because there was coal there and no oil.
A fairly simple way to convert a coal-burning model to an oil-burning one is just to remove the little plastic “coal” piece and cut a piece of styrene to go over the hole in the tender–with or without rivets. An oval or round piece of styrene maybe 2 feet wide serves as a “gas cap” for your oil-burner.
Well, Jetrock has written the answer (17 years ago) I’ve been seeking. Just walk into ANY hobby shop and look for an oil-fired locomotive. Unless you’re in the market for an SP Cab-forward or an SP class 4-8-4 you’re pretty much out of luck. And now Jetrock tells me “just cut out the coal bunker and cover it with a flat piece with a hatch”. How cool is that? I do see that Bachman is now offering an 0-6-0 oil burner. It just seems strange that since so many of the Union Pacific, Southern Pacific and Santa Fe locomotives burned oil, there are no models reflecting the type. Maybe it’s because coaling towers are huge, complex and impressive to have and oil servicing is just a hose surrounded by oil soaked ground.
Thanks for the insight!
A lot of wisdom to be found here. I hope these old posts remain so they can be referred back to when needed.
only the manufacturers really know why they favor coal over oil tenders but I suspect it’s because they can reuse the same tooling. Anyway it has long annoyed me as well since I model western railways.
The documentation I’ve seen indicated that the earliest practical application of oil fuel to locomotive firing dated to the early 1880s. This involved heating broken rock or refractory pieces on a firebox grate and then spraying oil over it – this both carbureted and cracked the oil and served as flameholding.
Practical use of the grades of oil that were most “economical” (read: cheapest to source and use) were facilitated by the early development of steam-atomizing burners, often of the ‘drooling’ type like the famous von Boden-Ingles type used on ATSF. These used steam both to heat and atomize the oil at the point of delivery and introduce primary air through long slots in the burner, the result being a long, flat plume of luminous flame filling the firebox volume with minimal impingement on “firepan” or internal firebox surfaces. Usually this was installed at the throat, firing back into the firebox space, so that the heated combustion plume would pass around a masonry arch and back over the crown, increasing both the TOF available for combustion and the area exposed to luminous radiation (the uptake being proportional to the fourth power of temperature).
Some experiments were done with other burner types over the years, but comparatively little involved mechanical atomization (as in the Racer burners in marine practice). The late version of Southern Pacific practice was a device called the Gyro-Jet burner, which used vanes to swirl the oil and primary air to get better atomization and entrainment with heavy oil.
SP did a careful comparison testing of different designs of burner in the early Fifties, right at the practical end of innovation in oil-fired steam in the United States, and wrote up the results in a study published in 1951. This is available in a couple of formats (see for example the link in the recent thread on RyPN). I have the PDFs but they are too large for conventional e-mailing, even if
In this cropped view of the CPR’s Drake Street Roundhouse, circa 1916, you can see what is probably the oil tank repair area along with the gantry necessary for lifting the tanks out of the tenders. An oil tank ‘insert’ is hanging under the gantry:
CPR Drake-St Roundhouse by Edmund, on Flickr
The New York Central converted some 20 or so K-11 Pacifics assigned to the Adirondack Division as the state of New York decreed that only oil burners would be permitted in the forested areas during the summer months.
Also there was the Mohawk, 2873 streamlined for the Rexall Train that was converted to oil for the duration of the special assignment.
Good Luck, Ed
Ed, you forgot Baldwin 60000 and, I believe, the Timken Four Aces. (Bet you have some fun material on both…)
Athearn/Roundhouse is doing a run of 2-8-0s for oil fired soon here - you can also pick them up on occassion used. Luckily as well, if you are up to some styrene scratchbuilding and painting, an oil box over the top of a coal tender tends to be much easier than turning an oil box into a coal tender.
Edit: I believe that the ATSF, UP, and V&T prototypes are all built with oil tenders.
