Whatever happened to the nuclear powered locomotive?
When the US Navy launched the Nautilis, smaller reators were to change propelling everything. The Air Force planned and did serious research on a nuclear powered bomber. The S.S. Savanah was launched into the merchant marine. What of land transport?
I inherited a video tape of an NBC documentary on railroads. It was done nearly 50 years ago. Chet Huntley tells of the promise of nuclear powered locomotives over a video of design engineers wearing narrow ties and pocket protectors looking over a drawing of a strange object inside the shell of an EMD cab unit.
That future is now. Whatever became of nuke powered locomotive?
First, it is technically difficult to provide really adequate shielding within the geometry of a locomotive.
Second, there is an alternative way to use nuclear power for rail operations: electrification, and generation of the electricity by nuclear power plants. Of course, that runs into…
Third, the collection of NIMBYS, BANANAS, and other assorted weepies with tremendous political clout and little or no brains have effectively stymied the use of nuclear power for anything, despite the proven safety of such power and the equally proven reduction in greenhouse gasses and global warming associated with a switch to nuclear power. Go figure.
Oh no! not this subject again!
Basic reasons, they proposed this in the 50’s part of the ‘Atoms For Peace’ program.
Too Expensive-
Too Heavy-
Too Risky-
The proposed loco was designed to be as much or more HP as a then standard lash up of 4 F units, trouble was that because of the radiation sheilding required it made the loco so heavy that half that HP was needed just to move the loco!, and given the complexity of the engine, each would have cost far far more than a standard dismal lash up so no RR wanted to buy into it. Then there was the risk of radioactive contamination from an accident, that put the nail in the coffin.
Better alternative to diesels is to use conventional overhead electric trains and powerplant generated electricity, nuke or otherwise.
Concerning the nuke bomber, I believe a B36 was used as test bed for an airborne reactor. The Air Force got the reactor in the air with all of its tare. As with the locomotive, all the lead shielding left little else for moving payload.
Poking around on the N. S. Savannah, the cost of decomissioning was a pricey issue.
They built the plane, even loaded a mock reactor, they even did some ground tests with the engine system, but the prospect of a multi-million dollar airborne nuclear reactor colliding with a $2K Piper Cub and spreading a nuclear debris field over an area the size of a small state, kept them from ever trying it in the air.
PS they used a B36 because the fact that the plane was soooooo heavy from the radiation sheilding, that was the only plane that could get it airborne, even then the sheilding was "thin’ to keep the wieght down and the flight crews would have only had a very short exposure time (1 hour max. flight time comes to mind) before, well, lets just say I hope they had kids before they took the flight. Lets just say no one was lining up to “volunteer” for those future flights. So they cancelled it.
The engines from the airplane still exist. They were recently put on public display next to the decommissioned reactor that was used to supply power to the first city to be lighted by nuclear power, Arco, Idaho. These engines are bigger than locomotives.
Incidentally, next to these engins, also on display is a locomotive that was used at the Idaho National Laboratory to move high radiation material around the site. It has a relatively small deisel engine, but the operator’s cab is a large cylinder with walls 18 to 24 inches thick. One window, in the front made of many layers of lead glass, about 12 inches in diameter. The crew was sealed into the cylinder during the operation.
Idaho National Laboratory is located about 40 miles west of Idaho Falls. The displays are classified as a National Historical Site, on the grounds of the I.N.L.
Can you imagine a derailment? uhh…bob, can you take that rerailing frog over there…bob?..come on we only have ten miutes of exposure time here…where’d you go?
Larsend - I think that locomotive is standard gauge but some of the tracks it was used on were 4 rail, with two sets of standard gauge tracks separated by 54.5 inches. The locomotive would run on the inside rails and to hot material was carried on double-wide flat cars with 2 sets of trucks on each side, running on the outer pairs of rails.
There was also the rumor that that locomotive was nuclear powered but it is conventional diesel as you described. Thanks for letting me know it is on display now. I’ll have to go see it.
There was also project PLUTO, for a nuclear powered rocket, they said after the rocket dropped its warheads it would fly around the enemy country spewing out radiation. Who thought science could be so fun.
It would be fun to build a nuke locomotive and send in across the country to pick up nuclear waste from research laboratories for disposal at the new doomsday storage site in Nevada. Would the gray pony tailed buzzards at Berkley, or Madison, show up to protest?
If it directly effects their research grant money, it usually works like the mute switch on your tv remote.
I recommend the National Atomic Museum in Alberqurque, NM. dedicated to the history of atomic weapons in the US Air Force, now I’m no fan of nukes but I found it a riveting place! Full size A-bomb and H-bomb casings the size of truck, lots of displays, got my pic in front of the Fat Man casing and they have a great film on the history around the Trinity bomb site, didnt get to go to Trinity, thats only once a year and has to be reserved well in advance.
Hmmmm, looks like FM built the atomic locomotive.[(-D] This bomb [8][B)][xx(] was rated 0*s by most reviewers! Now, how did I get away with that pun?[V][swg][(-D]
Nuclear powered train?? Seems like there were so many things that were going to happen in the wonderworld of the 21st century that never happened. Personally, I’m with Ralph Kramden - I ain’t getting a TV until they come out with the 3-D version…
