What's a good Method for Cutting Metal out of Loco Body
What is a good method for cutting down the weight in something like the narrow body locos? I have several to do next…a GP18 first. For my first two or three I have just hacksawed out chunks by hand. Is there a good/better hand-held tool, power or otherwise to do the job?
or…
I’m not sure how expensive something like a hobby sized metal-cutting floor or table bandsaw or jig saw would be, or if they would even work better. But now I am moving to a bigger location and so may even consider a more permanent cutting/milling tool for all these conversions.
Thanks.
I don’t do this sort of stuff, but the fellow who fixes my problem locos has a milling machine. That would probably be the best way. If you have the bucks, the long-term interest, and a hefty need to alter a whole bunch of locos, it might be a good investment for you. I can’t recall the name (Micro-scale?), but someone will have it.
Cisco,
For controlled metal cutting, milling is the way to go. You can hold and support the frame in a vise and control the depth (or Z-axis) of cut down to a .001". A good quality endmill (i.e. cutting bit) is also important and will be an additional expensive.
If you know pretty much what needs to be done, perhaps the cheapest and easiest way for now would be to have a machinist do it for you. They are usually paid by the hour and cutting frame metal would be fairly quick work.
Find a shop that does low volume and tell him what you want done. A working drawing (with the loosest tolerances possible) for each different locomotive frame is both helpful and will ensure that the job is done right. The looser the tolerances, the faster (faster=cheaper) the work gets done.
Do you know how much of the frame you need to remove on each locomotive? Is it the same for all of your locomotives?
You can use a Dremel. Be prepared to go through a lot of cutting wheels, though. I got a bulk-pack of cheap wheels (not Dremel brand) at Lowes. When one breaks, well, who cares? Take it easy, and when the tool itself starts to feel warm, give it a break and let it cool down.
Think about where you’re cutting. It may be that if you move over a quarter-inch, you can take advantage of an existing notch or groove and save yourself some effort.
If you have a lot of locomotives to work on and can justify the cost, Micro-Mark sells the MicroLux miniature milling machine for $499.95. I think Harbor Freight Tools has a larger one for less money that will do just as good a job, too.
When I needed to grind out space for a decoder from two Kato NW-2 frames several years ago, I used an electric grinder, but a milling machine does a much neater and faster job of it.
I tried a Dremel, but the motor overheats from trying to do something like this, and the blades tend to bind and cause it to kick back.
For milling out the white metal loco weight in my Rivarossi 2-6-6-2 I used a variety of cutter bits instead of the cutting wheels. The bits are safer to use than the brittle wheels and are coarse enough that they don’t plug up. Don’t run them at too high a speed. I found that step two worked just fine. Don’t get in a hurry,you can make a good little pile of chips in a hurry. One could also use a drill press with a cutter bit and a drill press vise to slide on the table. This process WILL work and won’t cost you $600.
