Driving home from work tonight, I paced an empty Dakota and Iowa train. In the country, the speed was 45-50 mph. As it approached town, the speed slowed to the low 20’s. Through town, it usually waddles along fairly casualy until it hits the big hill, then it slows down.
Obviously, there is some form of speed limits out on the railroad lines. How is that information about what speed limit a train should adhere to conveyed to train crews? Is there a penalty for speeding on a line?
Speed limits are generally conveyed both in the Employee Timetable and by roadway signs.
A common timetable format is the headline "Maximum Speed on this Subdivision is 70 MPH, followed by a long list of exceptions, that is places where a lower speed is required. In separate items speeds of various types on trains are likely to be limited, say mixed freight to 60 and trains over XXX per operative brake to 45 or 50 MPH, unit oil trains to even less. Practical effect is intermodals get 70, unless the TPOB limit catches them. Mixed freight usually about 60, unit trains less due to TPOB limits, and oil even less just because.
Roadway signs are standardized by carrier, but not between carriers. They are usually given in either Employee Timetable or Special Instructions.
Yes there are penalties for speeding. This is regulated by the FRA, and I never had to deal with it so can not say much more.
The Employee Timetable states the Maximum Speed for each line segment as well as any permanent speed restrictions.
Temporary speed restriction are conveyed to crews through the rules that pertain to train bulletins.
Weed Weasels have radar guns and will check train speeds; additionally track workers have a good sense of speed for passing trains. Add to this the various downloadable data that contains speed and GPS location data and Engineers have very little opportunity to ‘hide’ speeding (if they are so inclined) or get caught for speeding when operating in an area where various rules override each other.
When ‘prosecuted’ time off (unpaid) will be assessed. With multiple failures, dismissal is a real possibility.
10 mph or more than 1/2 the maximum speed over the limit (whichever is less) is considered speeding. Don’t worry, they’ll be talking to you if your a few over consistantly.
From a handout I received some years ago, first offense is 30 days suspension and 3 years probation. Second offense is 1 year suspension and 3 years probation. Third offense is 5 years suspension. Violations can also carry monetary penalties. Those are (or were if they’ve been updated) what the law required. The railroad could impose harsher punishments, like 6 months for a first offense.
The listed penalties also apply to passing a stop signal (without authority), brake tests, main track authorization, tampering with a safety appliance and a supervisor or pilot fails to take appropriate action.
Let’s see if I have this right. The line I see the rock trains on runs from Dell Rapids, SD to Sioux City, Iowa, about 80 miles. The north portion is owned by the D&I, the south portion by BNSF. At Sioux City, I think I’ve read where the rock trains also traverse a bit of CN trackage.
Does that mean that the D&I crews receive Employee Timetables from all 3 railroads? Does the crew have to have an employee timetable with them at all times? As far as the exceptions go, would they be listed out by milepost or such? If the exception says “20 mph between milepost 53 and 55”, presumably that means the engineer has to account for that in his braking before he gets to milepost 55?
Jeff- wouldn’t a 3 or 5 year suspension from a railroad job be pretty much a permanent career change for most people?.. 30 days suspension, 2 weeks on the job, 1 year suspension, 2 weeks on the job, 5 year suspension… Dang! Working only 4 weeks out of the last 6 years might be enough to force a guy to look elsewhere. [:o)]
Murph - I carry two timetables, and all ancillary documents (bulletin orders, summary bulletin orders, general orders, etc) for the two lines I’m qualified on.
And I carry them whenever I’m on duty. They are in my grip, along with the NORAC rulebook (applies to both lines), extra forms, and stuff like my lantern, gloves, safety gear, etc.
So the answer to your question on paperwork is a resounding yes.
Timetables and bulletin orders will often carry additional information about things like slow orders, like whether signs are posted (usually some distance out) or if the restriction applies to just the head end or the entire train. Regardless, if I’m supposed to have the train at 20 MPH between MP53 and 55, I need to pass MP55 at 20MPH.
I know folks who may run at a half dozen or more locations around the country. They have to have the appropriate paperwork for each. Oftimes running on a line you haven’t been on for a while involves getting your books caught up before you go.
Not only must they have the appropriate carrier timetables, they also need the appropriate carrier Rule Books as well as train bulletins for each carrier they operate over.
Foreign carrier Book of Rules, Timetables and Bulletins are not required at railroad crossings at grade. (BNSF isn’t required to have UP’s at Rochelle - If the BNSF engine that operates up the spur just west of the crossing would go to UP’s Global 3 - then it would need all the UP documents, unless the BNSF TTSI specified otherwise)
Yes the rest of the train follows the speed of the head end - however, Head End speed restrictions apply only to the lead locomotive - after it has complied at the specific milepost, they can accelerate the train up to maximum track permitted speed. Regular slow orders apply to the entire train, a signifigant difference when you have a 10000 or 12000 foot train.
Only place we have a head end only restriction is going through a city. There’s about 15 crossings in a mile, so the speed drops from 50 to 40 (used to be 25). But once you clear most of the crossings, you pick can pick it up again. Now your marker is going to fly through town at 50, but you already have the crossings blocked, so no biggie…
What is a grip? Is it a railroad specific item that you buy from RailroadsR-Us, or is it called something else by the rest of the world?
Considering the lack of trackside weigh stations or Highway Patrolmen on the tracks, who checks to see if you have the right timetables, bulletins, etc. on your run?
Grip is your luggage for all your railroad crap. Mine is a 8 year old Carhartt bag. There are specific companies that make RR grips: Red Oxx and Autumn Creek, I believe. But I’m too cheap to buy one of those.
Any member of the friendly local management team can check your bulletins.
Think of a ‘grip’ as a kind of man-purse, or the more ordinary version of a doctor’s little black bag. The term is a bit archaic but still ‘around’ enough that I knew what it was before I knew railroaders carried them.
Norris, a grip is basically a soft industrial-grade briefcase. It carries your books, a change of clothes, lunch, and other stuff you might need on the railroad. I never owned a real grip–with all of the rulebooks, special instructions, bulletins, etc., I needed just to stay in the yard, I had a 30-pound (I’m not kidding!) backpack. It would be unsafe to wear a backpack around moving equipment (and we all heard about one fatality on NS that was caused by the employee getting her backpack snagged), but I used that when riding my bike to work, and it had a good handle for carrying like a grip any other time.
In the yard we were required to carry the general orders and track bulletins for any subdivision we might have to work on. Even though I didn’t escape the yard in the course of my assignments, I had info on the Geneva Sub and the Milwaukee Sub, as both of those had Proviso as an end point or a point shown off the main line.
I also was required to carry a CORA book. CORA is the Chicago Operating Rules Association, and the book contained pertinent timetable and special instructions for every railroad in the area. That’s why it’s been fairly easy for me to compare signal rules of one railroad to another around here. I doubt that I ever opened the CORA book in the line of duty (except to take rules tests on parts of it), but I also made sure that it was never out of date as long as I was working. (To a railfan, the maps, speed restrictions, and signals would be fascinating, and the radio channels might be helpful.) When these first came out, they were closely monitored so that copies didn’t escape…yet when I went to my first railroadiana show post-CORA, there it was!
It used to be, on CNW, that a lot of the backwoods (sorry, backgrass!) crossings protected by gates had head-end speed restrictions on them. You slowed down to a walk to cross them, then speeded back up to a dogtrot once the engines cleared the diamond.
Mine came from Harbor Freight. Some folks use a cloth duffle, or a soft briefcase, as already mentioned. I’d use my soft leather briefcase, but I use it when I travel, too, so I’d be changing stuff back and forth all of the time.
A lot depends on what you carry - ie, lots of paperwork, or other items, means a larger grip.
A check of your publications is part of our check rides, and sometimes efficiency tests, not to mention the occasional spot check. Since the current B.O. is part of what the dispatcher dictates to us on our Form D, we’re constantly reminded of at least what that B.O. is.
