Where to put the caboose? (not as stupid as it sounds)
Direct quote from Peter Josserand’s classic Rights of Trains, the ultimate authority on all things rule-wise before and during the transition era:
Train: A locomotive (or locomotives,) with or without cars, carrying markers.
Mr Josserand goes on to explain (in excruciating detail) how trains get the right to occupy the railroad. Through it all, as long as there is a locomotive headlight on the front and markers at the rear, it makes no difference if the movement is a two mile long string of coal on wheels behind a half-dozen of the latest and greatest or a GE 44-tonner running light.
One train I would have liked to see was the movement of brand-new 4-10-2 locos from Baldwin to Southern Pacific country in the 1920’s - 20 locomotives and a caboose - carrying markers.
Chuck (modeling Central Japan in September, 1964 - with working markers)
OK, so you have to have a locomotive, and EOT markers. Pretty simple… I was figureing “train” as a sting of cars with a loco(or locos) and a caboose, though I could see it being a loco and EOT markers on/a caboose immediatley behind the tender.
A train is anything that the operating department (by whatever name) decides to call a train.
What is the front of a train, the back of a train and where a caboose is required to be is also determined by the operating department of the railroad. This may change from era to era and, to a much lesser extent, by location.
While it is true that the rear of a train that is required to have a caboose (as above) is the last vehicle and that will be carrying the marker(s)/flag/eot NORMAL practice when a caboose is involved is for it to be the last car - for all the reasons I’ve stated above.
When the ops dept is defining trains, or a movement as a train it can include On-Track-Machines as trains or not. Just to make life easy they are sometimes classed as a train in their own right and sometimes the same machine(s) aren’t classed as trains. If you have the Rule Book you might figure it out.
Even a humble inspection car can be designated as a train.
Exactly the same thing applies when determining whether a very long track run under a bridge is a bridge or a tunnel. If the engineers say it’s a tunnel, it’s a tunnel… if they say it’s a bridge then it’s a bridge.
Something to bear in mind is that if you get right out in the wilds and no-one will be looking the working that goes on isn’t necessarily “approved”. usually “variations” will fall within “grey” areas that can be talked away so long as nothing serious goes wrong. Most of the time nobody will take any notice so long as the job gets done safely. The problem is always to keep things in the “grey area” within bounds and to not start to assume and get into sloppy practices. As in almost any industry people start to assume. “Local Practices” that “everyone knows about” are a constant source of stupid, avoidable and sometimes fatal incide
Not sure if this came up earlier, but it depends too on how a line is designated - for example, inside of specifically designated “yard limits” areas, you can move cars without a caboose (like when you’re switching them in a yard obviously!!).
Some railroads had yards where the yard limits extended a mile or two beyond what would appear to be the yard itself. In fact one railroad - I think the LS&I?? - officially listed their entire railroad as being “within yard limits” back when cabooses were still required (c.1980). Since the whole railroad was within yard limits, they never had to use a caboose !!
I was filping through a copy of the NS 2005 annual report and was looking at the number of freight cars owned by type and I saw NS still owns 200 something active Cabooses. I contacted Ruby Husband the manager in charge of northeadtern operations and asked him what they are for. He said NS uses them when they have a special (military weapons, nuclear waste, etc.) and when they push a train more then 1 mile, they put it in the front of the train.
Don’t you mean that they put it in back of the train so that when they go back in a push move they have somewhere for crew/ a pair of eyes to ride (safely inside rather than hanging on the stirrup/side) at what has become the front… so that the caboose is in front of the train going backwards… [%-)] … I think I’ll go and watch cricket… [sigh]
Yes that is how you could put it…
Excellent question, James.
-Ed
