Given a single stall, wooden engine house of the steam era where there is no turntable (maybe a nearby wye), was there a proper way to drive a locomotive into the shop – always forward in and backing out, or tender first and driving out for’ard? Or was it engineer’s choice? Or did each road have its own policy?
Roundhouses had the engines enter with the tender towards the turn table, that put the valve gear and cyclinders, the stuff they needed to work on the most at the wide end of the stall with the most room.
With a square engine house that doesn’t matter since the stall is the same width.
Easy answer. Look at the roof. Where is the smoke jack? Normally there is a vent or smoke jack at one end, that is where the smokestack of the engine goes, under that, to vent the smoke from the engine.
…that’s what I’ve been told, and as far as I’m aware, that’s why the smokejacks are near the back of the roof on the roundhouse…
…and the smoke collector hoods are immediately beneath the smokejacks.
I also recall that the hinged smokebox-fronts can be opened, so that the cinders can be shovelled-out…probably into wheelbarrows, as there’s more room at the back of a roundhouse than there is at the doors.
I have a friend who parks his locos in the roundhouse with all of them facing outward at the doors, simply because the front ends are more interesting than the back-ends of a tender.
So, I just did an image search on Google for HO Scale Single Stall Engine House, and I am now so confused.
Some had the smokejack on the same side as the door, some opposite, some both, and some had no smokejack. One model had four smokejacks along the roof.
Unfortunately, there is no smoke jack, and the vent is in the middle of the ridge:
The teenager who build this shed back in the late 1970s modelled it after something he saw in an issue of MR, probably, or in the Walthers catalog. If there was a smoke jack, he neglected to include it. I’ll have to have a serious talk with him about that. But I suppose the middle vent would enable ambidirectional entry?
Oh, and look, there’s ol’ one-handed Clem. He got to showing off while greasing the boxes on a rolling train one day and fell under a boxcar and lost that left hand. Still, he can climb a ladder using just his right. Everybody loves Clem, even though he swears like a fish.
In regards to the roundhouse orientation with the pilot toward the outside wall, those tall windows were another reason the “business end” of the locomotive went in front first. The windows provided plenty of light, at least for the second trick shop men.
As far as the little wooden shed goes, I doubt an engine would have been placed in there with a live fire. The fire would have been dropped in the ash pit and the engine run in under residual steam pressure.
When the time came to put a new fire in her the engine would have been pulled out past the doors so the smoke and cinders would be free to escape. OR there would have been a smoke jack installed.
The little cupola on the roof would have provided some ventilation and relief from the heat of the boiler but wouldn’t handle much in the way of smoke and ash.
Ed, thanks for this. Very interesting drawings. It would be easy to add the top of a smoke jack at the far end of my wooden shed.
Didn’t even think of that. I suppose there would have been an ash pit under the track somewhere ahead of the shed and that it would have maybe a slanted access on one side to get a wheelbarrow and shovel down there? I’m trying to envision it.
Interesting. I don’t know how the engine could be pulled out of the shed unless by another engine, and there won’t likely be one. This is the terminal end of a small branch line. I had decided against a turntable – just too cramped a space – so the loco comes up the grade forward, and I thought maybe it would park in the shed pilot first overnight, then take the morning mixed local back down the branch. But if it takes another engine posted locally just to pull the first one out of the shed every morning, that’s not very efficient.
Could a small donkey steam engine be permanently located off to the side of the front of the shed to pull the locomotive out? There would have to be a way to straighten the cables since it would be pulling obliquely. I’m just spitballin’ here…
Didn’t roundhouses and garden tracks, then and now, have a boiler house that could pump enough steam into the locos from overhead pipes to get them onto the turntable and then to the coaling station?
Yes, steam was a common utility in the, um, steam era. Generally any service area would have a boiler house that provided steam not only for the roundhouse but for outlying buildings for heat, steam-trace lines to keep pipes from freezing and heating domestic water and, if there are any passenger cars kept in the area they, too, would be on steam…
The single-stall wood shed the OP is asking about probably wouldn’t be large enough nor would there be another locomotive nearby to tap into a supply of readily available hot water/steam. Depending on how much “headroom” there is in the boiler the engine could be moved a bit on compressed air.
Larger facilities had “firing sheds” where the hostler would move engines for building of a new fire. This photo shows a blower system in order to induce draft:
Obviously a Pennsy facility. Speaking of PRR, I’ve seen photos of roundhouses and outdoor engine service areas that are equipped with smoke extractors that would fit over the stack and collect smoke which, I believe would be scrubbed, then sent out a tall stack at a distant location.
Scroll down here for another look at a “Snow” smoke extractor:
They pulled in front first. If they didn’t fit then the tender hangs out instead of the locomotive which is getting serviced. The engine house is to protect the locomotive and the workers from the elements. The tender is not as important. Here is a picture of the Santa Fe roundhouse in San Bernardino California circa 1940s.
You need to add a little more imagination…there’s no reason that the fire couldn’t have been banked, with an employee knowing at what time he’d need to get the fire hot, so that the loco could move under it’s own power when necessary.
Ash pits were very prevalent near the end of rural tracks serving small towns, and somebody in that town could have earned a little dough by dropping the ashes and watering them down. Once it cools down it could be used for pathways, and I recall seeing lots of such paths near, and along the Grand River in southern Ontario.
These answers have all been very instructive and encouraging.
I believe I will scratch-build a small boiler room tight against the shed on the near side in the photo, between the little back door and the windows. The whole shed will need to be moved over a bit to accommodate this but I was going to move it anyway because of track changes. I will also install a smoke jack toward the back and, if I can find a photo of what one looked like, an ash pit out front. Then I think I will feel good about bringing the locomotive into the barn at night and backing 'er out in the morning.
This thread has been a very helpful one for me. Thanks all.
In our town there were smelting operations that required a boiler house.
The smelting operations have long since gone but the structure that held the boiler and office still remains.
It is a non-descript stone structure with a corrugated metal roof- -think powder house- -where, in case of a boiler explosion- -the force of the explosion would be channeled up through the “weaker” roof structure by the stone walls.
The footprint is two (2) small square structures that share a common wall. The boiler room has a separate entrance facing away from the office with two (2) windows.
Placing a small stone structure up against the engine house seems feasible.
As far as adding a smoke jack to the engine house have you considered only adding a single smoke jack in the center of the cupola?
On the inside of the engine house there could be an upside-down “T” shaped vent with a damper in the center to open or close one end or the other, depending on which way the engine is oriented.
Because this is inside the engine house you wouldn’t have to model this venting as it is not visible from the outside.
Another option would be to put a smoke jack at each end of the engine house with a damper on each to open and close depending on which way the engine is facing.
Hope this helps.
Post Script: Don’t be to hard on that “kid” he did some great work back in the day! H.T.H., J.J.D.I.
That is one of the most useful posts I’ve ever seen, directly applicable to the fallout from my original question. Two things:
What town are you referring to. I have ways of getting at old and new satellite imagery and I’d like to have a gander at this boiler house. Don’t worry, I won’t spy on your garden gnomes.
What do you mean by this? When we say jack, we mean the circular chimney with a little half circle over the top, right? I only know this term from cabooses. Are you saying one of these would protrude up through the top of the cupola? Or next to it on one side? I’ve never seen that so having trouble envisioning it.
EDIT: Well, now looking back up at the photos others have generously provided I see that the part of the smoke jack showing above the roof can take a number of different shapes, But still, one of these narrow cylinders rising out from the cupola? Just want to make sure I understand the proposal. (I also like the idea of doing one at each end, probably even easier).
Ed, yes, we’re all saying “smoke jack” up in here. And I used the term to mean what I understood others to mean, but was pointing out that prior to this thread, I thought a smoke jack was simply a tin pipe for a wood stove, mainly on a caboose. So I was trying to clarify that we’re talking about this entire smoke gathering/dispersal structure, above and below the roof.
And yes, I saw your drawings. They’ll be useful if I decide to put a smoke jack at either end. What I meant when I said I was having trouble envisioning it was where jjdamnit suggested I put a smoke jack coming up through the cupola on my wooden building shown above. That’s what I am having trouble envisioning. I can clearly envision installing at each end one of the above-roof items I’ve been shown here.
Hope that clears things up, and thanks for pressing the issue. [:P]
