I have used normal elmers white glue to glue woodflour between the track and building what is the estimated drying time?
Thank you
Thank you
14 minutes, 28 seconds
Depends! What the surfaces are being glued and what the humidity is, will effect the drying time. I remember one post that when gluing extruded foam together, somethig like several months later, though the edges had dried to hold it together, the center had not dried, as no air could get to it.
Good luck,
Richard
