Who's Ready For a Modernized GP38?
The QSK50 and QSK95 are V-16 cylinder, 4-stroke diesel engines manufactured by Cummins. The similarities end there. The QSK50 is a 6.25 x 6.25 bore and stroke; the QSK95 is 7.48 x 8.27. Different heads, intakes, etc. The QSK95 was introduced in 2015; the QSK50 was around at least six years earlier.
There is a V-12 engine based on the specs of of the QSK95 used in marine and stationary
This is getting to the meat. One of the stated reasons for the relative failure of Cat engines in railroad service is failures, occasionally catastrophic (no pun intended), when the maintenance including intentionally expensive parts is not strictly followed. Can you state what the problems on the QSKs in railroad service from ‘typical’ (to EMD or FDL scope) maintenance attention have been, and what implications this has for maintenance priorities in future?
Calling that an ugly locomotive is unfair to the word “ugly.”
Looks more or less like a GP38 to me.
Admittedly that’s not much of a Bicentennial scheme, but I’ve seen worse paint on GM demonstrators…
Perhaps he was referring to the rather challenging GPL38S rather than the rather inoffensive GP38CC…?
Of course the air filters aren’t easily worked into a smooth outline…
As I’ve posted earlier, the GPL38S and the SDL38 are both specific export units for a particular customer for whom a light weight version of a domestic unit is more suitable than a straight export unit.
Neither of these are likely to have any influence on domestic units…
The CP GP20 ECO has more in common with the GPL38S than any other domestic unit and the “38” is an export oriented description, not related to any previous domestic unit.
Peter
I don’t really mind that one either – in the orange and white it’s a bit reminiscent of a GP10, and I saw very similar cabs on a pair of CSX 40-2s yesterday evening. The air filter gives it a sort of Alco Century/C39-8 flavor – granted, not something everyone would like, but not as bad as frogeye lights on the short hood…
One reason would be that EMD doesn’t have an AC motor that fits in the place of the D-series DC motors, the smallest is about 2" greater from axle to transom. The truck frame can be carved up but it’s a lot of work, especially to accommodate the dogbone link used for the nose support since the first AC motors at EMD. We shoehorned it in for the F69PH-AC’s but those were new castings done with pattern mods and some welded pieces added.
The motor bellows to the underframe and the motor air outlets are no different, but I can’t recall if there is a larger deflector at the lower outlet outside the wheel, which was there to avoid blowing so much stuff off the ballast. The traction motor blower and underframe ductwork is no different, other than the blower wheel may have more blades to compensate for the greater total system resistance. I never saw details of the filter system itself but the design was to take advantage of the clearance diagram and get the intake as high as possible.
Thank you for that. The F69 predates all of my coworkers and thus no one could tell me anything about it. In short, that traction motor is not a ready insert into a Blomberg. Curious about the ABB 3-phase traction motor used on the F40 202.
I was referring to the GPL38S in the photo in the original post.
I just think the air filter box up there just kills it. Otherwise (albeit a huge “otherwise”) it looks fine. The paint scheme is okay; I like it, actually.
It’s a funny thing. I’ve liked ‘humpbacked’ skylines, with big stuff behind and over the cab, since the days of the big Alco Centuries, including the dash-8-39s, but I think the low-nose GP30 is one of the worst looking locomotives of all time, right up there with the BL2 and the Gravel Gerties. And I didn’t think I’d get used to those ox-yoke air ducts any more than I thought I’d get used to that $1.35-of-loose-change-in-a-coffee-can idle of the PowerCerebrovascularAccidents either… but I did.
Had they painted the roof above the cab dripline black, most of the awful upness would be less obvious.
Without the airbox and its filters the engine itself would die in the sands of Arabia
Modernized GP38? How about a modernized SDL39!
https://www.progressrail.com/en/Segments/RollingStock/Locomotives/FreightLocomotives/SDL38.html
There you go: same trucks, 8-710 ECO engine.
Outside Saudi Arabia you could skip the air filters.
Note, the SDL38 is loco 4321.
3534 is a modified SD50, illustration included in error.
Peter
